It is currently Fri Aug 01, 2025 10:02 am
 Post subject: Spruce Top Scrap Wood?
PostPosted: Sat Jan 17, 2009 1:17 am
First name: George
City: Seattle
I'm looking for some split, damaged, lousy, good-for-nothing, inexpensive remnants of spruce tops to use while experimenting with various finish materials and techniques. Anyone have anything they would like to sell? Or a lead to a possible source? I've thought about using something from a lumber yard, but fear I won't get accurate results unless I use pieces of the real thing. Am I wrong? Thoughts and advice welcomed.
Thanks in advance,
George :-)
PostPosted: Sat Jan 17, 2009 3:00 am
Shane at High Mountain Tonewood might has some scraps or inexpensive sets (although he usually saves that stuff for the wood stove I think).
He's one of the OLF sponsors, you can find his link at the top of every page.
PostPosted: Sat Jan 17, 2009 5:43 am
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
LMI and other sellers sells 2nd grade tops fairly cheap (15 dollars or so) and you can test finishing on that. I am not sure if you have size requirements if not you can just buy a brace stock and resaw them into as many pieces as you'd like then just do your tests. The only difference between second grade and others is runout and presence of pitch pocket or knots or other non-straight grain stuff... should make no difference with finishing. The first guitar I just got done (going to Afghanistan too) had a second grade top.
I'm sure you'd spend more than $15 on a trip to the lumberyard and sorting the wheat from the chaff... you can cut it to pieces and do many many tests.
Typhoon Guitars
PostPosted: Sat Jan 17, 2009 2:46 pm
First name: George
City: Seattle
Found some! Thanks for the replies.
George :-)
Users browsing this forum: Colin North, DennisK and 7 guests
