It is currently Fri Aug 01, 2025 11:01 pm
 Post subject: Purfling cutter mod
PostPosted: Mon Jan 26, 2009 2:35 pm
A while ago i posted an easy way to turn a drill press circle cutter into something closely resembling the schnieder gramil sold by lmi.
I modified it again to accept a radiused scraper for consistently scraping the edge fluting on violins. It could easily be adapted for scraping the recurve on archtop guitars and mandolins.
I simply cut a slot with a thin hacksaw, allowing the cut to wander a little bit for a gentle curve. Then i jammed a cut down scraper blade into the curved slot, which eliminates the need for a set screw.
It is quite comfortable to pull around the perimiter, and it makes a time consuming job a little bit more brainless(which is good for people like me).
Jordan Aceto
Ithaca, NY
 Post subject: Re: Purfling cutter mod
PostPosted: Tue Jan 27, 2009 12:24 am
Thanks' Jordan, I just purchased a general 55 circle cutter after seeing your last post and was thinking of making a small brass holder to insert into the existing cutter slot and hold a small scaper in this manner.Regards,Chris.
