It is currently Wed Aug 06, 2025 3:48 am
PostPosted: Tue Jun 23, 2009 12:16 am
Last Name: Hammond
The guitar before last had fisheyes in the KTM-9 [xx(] , bad but managable. The next one had no problems. This one has fisheyes in the Z-poxy! Has anyone else had problems in the epoxy stage? I did not know it was even POSSIBLE to have hundreds of fisheyes in the grain filler. I'm beginning to think it might be a problem with the sandpaper, I used the Norton grey 320 grit from HD. Possibly a bad batch of paper ?!?!?? Someone told me that naptha will get rid of the silicone on the finish and allow you to continue on without sanding completely back to bare wood. Help! Help!
The Biggest Little City, Nevada
www.hammondguitars.com
I love building guitars!
PostPosted: Tue Jun 23, 2009 4:00 am
Last Name: Fifield
City: San Jose
Zip/Postal Code: 95124
I hear ya! Annoying aren't they?! What kind of wood is giving you all this grief? I thin out the Z-Poxy finishing resin a bit with de-natured alcohol - it seems to help a bit, but then you have to give it 3 coats of Z-Poxy to make sure all the pores are filled. Can't win! gaah
I'm not sure what you mean by having to sand back to the bare wood - you're supposed to do this between coats of Z-Poxy filler anyway I thought, so that you end up with a totally flat surface with all the pores filled (they should look like tiny shiny dots when you are done)...?
I thought I'd heard it wasn't only silicone deposits that did this, but pretty much any mineral deposit in the pores. I'd like to learn more about this if anyone knows the whole truth here......
Cheers,
Dave F.
Cambrian Guitars
PostPosted: Tue Jun 23, 2009 7:54 am
The problem could be stearates in the sandpaper. I am not familiar with the Norton brand, so you might want to check that out.
PostPosted: Tue Jun 23, 2009 9:08 am
Hesh once warned me about the none slip router mats containing silicone
PostPosted: Tue Jun 23, 2009 10:40 am
First name: jack
Dave wrote:"I'm not sure what you mean by having to sand back to the bare wood - you're supposed to do this between coats of Z-Poxy filler anyway I thought, so that you end up with a totally flat surface with all the pores filled (they should look like tiny shiny dots when you are done)...?"
Jack replies: As long as you are still seeing "shiny spots", the pores are not completely filled.
PostPosted: Wed Jun 24, 2009 2:02 pm
First name: Nelson
Last Name: Palen
Fish eyes are not all that bad if properly prepared. bliss
PostPosted: Wed Jun 24, 2009 2:09 pm
Tobasco and some lemon helps.
PostPosted: Wed Jun 24, 2009 3:35 pm
Yeah, but you can suck on one for hours and it will never melt! [xx(]
PostPosted: Wed Jun 24, 2009 5:26 pm
Last Name: Hammond
This thread has turned revoltin'
PostPosted: Wed Jun 24, 2009 7:01 pm
At least it's not fish heads!
I'd look to another source for the contamination. Norton sandpaper is all I use and I've not had any fisheye problems.
PostPosted: Thu Jun 25, 2009 12:15 am
Last Name: Hammond
I'm thinkin' now it might have been the cup I mixed it in. I hope! bliss By the way, the U.S. soccer team finally looked like a real team today....... GO USA!!!!! [:Y:] [:Y:]
PostPosted: Thu Jun 25, 2009 11:03 pm
First name: duh
Last Name: Padma
contamination: Fish eyes are craters that have a bit of material remaining in the center.
Water, oil and silicone are the three major culprits. Air supply (needs good filtration, no oil, no water, extremely clean), environment (are you around any silica sand producers, is there any caustic or acid around, etc...),
blessings
the
Padma
