It is currently Fri Aug 08, 2025 9:39 pm
PostPosted: Tue Oct 06, 2009 1:16 am
Anyone using a home made peg shaver for guitar pegs etc? Or....what works with a violin peg reamer?
:P
PostPosted: Tue Oct 06, 2009 2:41 am
Use them frequently. They work and work well, they are a simple tool so that shouldn't come as a surprise. Just use the reamer that you have to form the tapered hole in your shaper and you will have a pretty good match. Depending on how much wood you need to remove (on the peg) you may need to make a few shapers.
PostPosted: Tue Oct 06, 2009 8:44 am
First name: Danny
Last Name: Vincent
I'd be grateful to see a picture of a home made one. My kid broke one a while back. I won't go into my crude approach to shaping a new one, but it worked fine.
Danny
PostPosted: Tue Oct 06, 2009 5:38 pm
Not a lot to see really. The important bit is to place the edge of the cutting blade above the centre line of the reamer - around about the 2 'o' clock position. The length of the cutter (the cutting edge) should also follow the taper of the reamer.
Even though I have the brass shapers I use the wooden homemade type. In use the blade is clamped with a through bolt. large washer and wing nut.
PostPosted: Tue Oct 06, 2009 5:47 pm
Looks simple enough to make, but, we shall see ... thanks!!
PostPosted: Tue Oct 06, 2009 7:31 pm
First name: tomas
Last Name: gilgunn
City: sligo
Country: ireland
hey thanks for showing
i would love to see a peg shaving tutorial
from the bone to the bridge
how do you guys roughly shape your pegs ?
off the bone or chucked into a drill press
i was often thinking of making one but wanted to
see one first and get a tip or two
what about an adjustable blade by thumbscrew
for getting the final shape (would it save time)
or do you just feed the bone into the tool with a drill ?
thanks
tomas
PostPosted: Tue Oct 06, 2009 7:39 pm
Its just like a big fancy pencil sharpener! 8-)
You should turn your pegs on a lathe first, but I am using storebought.
PostPosted: Tue Oct 06, 2009 10:25 pm
First name: george
Last Name: wilson
City: barhamsville
State: virginia
Zip/Postal Code: 23011
Country: united states of america
It might be helpful to some who may not know,that if you sharpen your cutters to a steep angle,so that they scrape,rather than trying to cut into the wood,the peg shaper will work infinitely better. It will do very smooth work.
PostPosted: Thu Oct 08, 2009 9:04 am
First name: Douglas
Last Name: Ingram
City: Lorette
State: Manitoba
Anyone have any thoughts about DIY reamers? I need to ream some peg holes, only 6 string pegs and 6 tuning pegs, not nearly enough to justify the cost of "proper" reamers.
http://redrivercanoe.ca/
PostPosted: Thu Oct 08, 2009 10:43 am
Ebay guy has some old 'guitar reamers', he seems to have a ton of them last time I looked, 10 bucks or so.
PostPosted: Sat Oct 10, 2009 1:03 pm
First name: Douglas
Last Name: Ingram
City: Lorette
State: Manitoba
+ $20 shipping!
I'll probably see if I can find someone to do me a favour.
Users browsing this forum: No registered users and 40 guests
