It is currently Sat Aug 09, 2025 10:32 am
Post new topic Reply to topic  [ 28 posts ]  Go to page Previous  1, 2
PostPosted: Fri Oct 16, 2009 11:02 am
Rough cut on bandsaw, followed by clean-up cut with blank clamped to a holding fixture on chop saw.
Perfect about 8 out of 10 times.
Tidy-up with Japanese hand plane, if necessary.
PostPosted: Fri Oct 16, 2009 1:46 pm
First name: David
Last Name: Malicky
Zip/Postal Code: 92111
bluescreek wrote:
I prefer the clamp method as the work is held stable. Even with a clamped sled ,you will have some slight movement. I learned this trick when doing miter cuts from an old cabinet maker. With the proper blade you are ready to glue after the cut. When you clamp the work it is less likely to move. I think we all have our favorite techniques. Not saying one is better than the other , but accuracy counts on this joint.
A simple jig as Todd shows is also good. The joints integrity relies on the mating of the joints face. This is a good joint when done right.
Yes, looking back on this thread, it sounds like John's method is more accurate, and I would trust his experience more than mine. I didn't know a thing about building guitars until 4 years ago. Our method is good for our purpose since it's quick, but it can leave a ~1/32" gap at one of the corners -- we just clamp the gap closed, but I imagine many of you would want better. Except for that corner, the overall surfaces do come out flat. I'm going to try John's method, too, and we may switch if it's fast enough.
6strings, I'm not exactly sure what you're describing. Are your surfaces flat? We do get saw-marks in a semi-circular pattern, but as long as our feed is slow and blade is sharp, these are pretty faint, and haven't interfered with glue-up.
David Malicky
PostPosted: Tue Nov 10, 2009 2:50 pm
Last Name: Charnock
Country: UK
Hi
I am approaching the point when I need to make this joint, I think I will try all three methods on some test wood first.
Band saw
Table saw
Manual cut
Has anyone ever raised table saw into the neck to make the cut, seems scary to me ?
