It is currently Mon Aug 11, 2025 1:27 pm
PostPosted: Sat Jan 30, 2010 3:21 pm
First name: Rob
Last Name: McDougall
City: Cochrane
State: Alberta
Hey guys,
For you who are expecting a delivery of Shanes' Lutz and have not used it before - check this out.
This is a shot of my current build - just for fun I thought I might give the top a little wash of Amber Aniline dye....
I could not believe my eyes when I saw this insane figure pop out:
PostPosted: Sat Jan 30, 2010 4:08 pm
Just curious. Did you R.O. sand that for final prep. What grit did you conclude with.
I sometimes see that figure and it seems to only happen when I random orbit sand in higher grits. If I hand sand it doesn't occur (that I have noticed)
PostPosted: Sat Jan 30, 2010 5:44 pm
What Brock said and I only see it when I use a ROS and 220 grit too. No worries it holds paint great.... :D
Seriously it's pretty cool and yet another reason why Lutz is killer wood!
PostPosted: Sat Jan 30, 2010 6:20 pm
First name: James
Last Name: Allen
City: Ashton
State: ID
Zip/Postal Code: 83420
Wow, is blowing my mind clear over here in Idaho. That is some nice wood.
Always remember you are unique......just like everyone else.
PostPosted: Sat Jan 30, 2010 6:56 pm
Country: Romania
It normally appears on all perfectly quartered, sanded spruce. I get it when I hand sand with high grits such as 600. When planed, the wood is cut flat regardless of its density and you don't get the effect.
Build log
PostPosted: Sat Jan 30, 2010 7:32 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
Shane's Lutz rocks. I am always totally blown away by how pretty and stable it is. and it is SO easy towork with.
PostPosted: Sat Jan 30, 2010 8:02 pm
First name: Rob
City: Cochrane
State: Alberta
Hey Brock,
No, I do not use the RO for finish sanding the top, mostly scraper to remove glue from the binding install and final block sand with 600....
RM
PostPosted: Sat Jan 30, 2010 8:58 pm
I have a Sitka-topped guitar in progress which shows almost exactly the same thing - nice, but it's not peculiar to Lutz.
Pete
Pete
PostPosted: Sat Jan 30, 2010 10:55 pm
Yeah, it tends to show up when you sand with 600+ paper.
Gwaltney Guitars
PostPosted: Sun Jan 31, 2010 7:04 am
Hi Robbie,
I have gotten this with Englemann Spruce. I have also seen it on some fine guitars made by Robert Ruck.
Max
Max Bishop
Brighton, Michigan
PostPosted: Sun Jan 31, 2010 7:26 am
Alexandru is right, most spruces and cedars will show silk characteristics when perfectly quartered. The exception is red spruce which, while occasionally showing some will not display it as well as Engelmann or Italian, Sitka and German.
Frankly, I prefer the look of a lot of compression grain. It's so old timey...
PostPosted: Sun Jan 31, 2010 9:23 am
I'm building one now with a Sitka top that has grain like that. Pretty cool top.
PostPosted: Sun Jan 31, 2010 10:12 am
First name: Richard
Last Name: Sprouse
City: Spartanburg
State: SC
Zip/Postal Code: 29302
Aren't these the medullary rays in he top?
PostPosted: Sun Jan 31, 2010 11:11 am
They have a different look than most tops I have. Looks heavier and "wilder" looking to me. When I first saw it on the top I'm working on, I wasn't sure I like it as much as the more even rays accross the board that I usually see. But it's grown on me and now I like it quite well.
Users browsing this forum: bftobin and 43 guests
