It is currently Mon Aug 11, 2025 6:15 pm
PostPosted: Thu Feb 04, 2010 9:58 pm
First name: Heath
Last Name: Blair
City: Visalia
i just put a couple sealer coats of shellac on this rosette for number two and i thought id show it off and get some opinions. im relatively happy with the way it turned out. i did get a little bleeding of the cocobolo purfling onto the spruce, but i minimized it and im moving on. the soundhole binding is a tad thinner than i was going for, but overall i think it looks decent.
the rosette is made from quilted sapele arranged in a radial fashion around the soundhole. purfling is cocobolo and flamed sycamore. the soundhole binding is also cocobolo, but its only about .020" wide. i think that might make it purfling and not binding. oh well. it is almost a full .250" tall and that idea was mostly stolen from paul woolson, so thanks paul if you are lurking around out there.
comments welcome.
i do have a question about the size of the soundhole though. i was shooting for a 4.125" soundhole and ended up with something over 4.250". it is an OM size instrument with a 12 fret neck. the soundhole is shifted south to account for the short neck, which is supposed to help support the lower end i believe. i wanted to balance things out with a slightly larger soundhole, but do you think i might have made it too large? i could close it up another .125" if i added a thicker soundhole binding, which i think might look better anyway. what do you think?
sweat the small stuff.
PostPosted: Thu Feb 04, 2010 10:54 pm
Heath, you have nothing to worry about. Lot of my guitars have 4.25" soundholes and sound ok.
PostPosted: Fri Feb 05, 2010 7:03 am
On a Martin OM the hole is 3 7/8 and the X braces passing near the sound hole may be too close . It depends on scale length and hole position.
Making the hole larger will take bass response away from the guitar . I don' think you will have any issues , just food for thought.
PostPosted: Fri Feb 05, 2010 11:14 am
Moving it south also reduces bottom end ... move it north to increase .... ask Al.
PostPosted: Fri Feb 05, 2010 1:03 pm
First name: Heath
Last Name: Blair
City: Visalia
Filippo Morelli wrote:
Heh ... I'm guessing a little bit better than, "ok", Peter ;)
Filippo
i was thinking the same thing.
thanks for chiming in guys.
the guitar is adi over hog so hopefully it doesnt have too much bite. i went a little deeper on the body so maybe that will help.
thanks again.
Users browsing this forum: Brad Goodman, J De Rocher, TimAllen and 31 guests
