It is currently Sun Aug 17, 2025 10:38 pm
PostPosted: Sat Jul 31, 2010 2:56 pm
Last Name: Sollod
I think I tried to spray nitro when it was too humid. There appears to be cloudiness in the finish. Will this go away? Do need to do something like use a hair drier on it? Any guidance you can give would be appreciated...
www.swiftcreekguitars.com
PostPosted: Sat Jul 31, 2010 3:01 pm
Last Name: Ressler
City: Sandwich
State: IL
Zip/Postal Code: 60548
You need a can of blush eraser (Stew Mac has it). Spray it on the blush areas and it disappears immediately
John Ressler
PostPosted: Sat Jul 31, 2010 3:46 pm
First name: jack
You could go to Lowe's or some other hardware type store, and buy a quart of lacquer retarder and follow the directions on the container..
jack
PostPosted: Sat Jul 31, 2010 3:59 pm
First name: Woodrow
Last Name: Brackett
City: Grover
Zip/Postal Code: 28073
Before you go buying anything try spraying a really light coat that's ~90% thinner, 10% lacquer. I've never used blush eraser, but too much retarder can make it take a really long time to cure.
PostPosted: Sat Jul 31, 2010 4:06 pm
First name: jim
Last Name: mccarthy
City: ojai
State: ca
Zip/Postal Code: 93023
I spray lightly with 100% thinner. Most often 1 shot will clear it up but sometimes two applications several minutes apart are needed.
I strongly suggest you wait for the humidity to drop instead of using retarder.
PostPosted: Sat Jul 31, 2010 4:13 pm
Last Name: Sollod
Okay, I found the Jet Blush Eraser at my local Woodcraft store. Thanks for the info. bliss That's why I love this forum... So how soon after I apply the Blush Eraser can I re-apply additional coats of nitro? I guess you need to let it cure for a period of time before you can lay more coats down... right?
PostPosted: Sun Aug 01, 2010 10:35 am
Last Name: Sollod
Thanks Todd (and everyone else). This is all good advice and since finishing is one of my biggest challenges, this info helps me a lot.
THANKS,
