It is currently Mon Aug 18, 2025 2:35 pm
PostPosted: Fri Aug 13, 2010 1:50 pm
First name: Big
Last Name: Jim
It seems that on every build I have trouble with the same thing over and over and over again . For me its a small thing , but i seem to manage to do it everytime . " Filing the nut " Getting the nut slots straight seems to elude me, I will almost ALWAYS have at least one thats crooked ! [headinwall] gaah Drives me batty !!
Whats the one thing that seems to Haunt you in your Builds everytime.
PostPosted: Fri Aug 13, 2010 1:57 pm
Binding channels - never perfectly even in depth or depth! gaah
PostPosted: Fri Aug 13, 2010 2:20 pm
First name: duh
Last Name: Padma
Yo, Wud,
Breath in breath out and then push the file.
Breath in breath out, push the file.
Any thought or emotion in our being is transferred to the blade, file edge or brush stroke.
Or as Leonardo da Vincie said "anything manifested by the being is an indication of the inner being."
They say when the breath stops, the monkeys in the mind stop.
So...only cut at that moment between breaths.
Is simple
Give that a go. See how that works.
blessings
duh Padma
PostPosted: Fri Aug 13, 2010 3:11 pm
Country: Romania
Filling every last darn rosewood pore with pumice, same for the odd small pit in the mosaic rosettes. These buggers tends to show up when French polishing is well underway.
Build log
PostPosted: Fri Aug 13, 2010 4:18 pm
I have a similar problem with ZPoxy. I tried a different approach this time. I thinned the first coat down with alcohol to get some wicking action down a little more into the pores. That and getting the surface nice and warm. I'll do the sand down tonight or tomorrow and well see how it turned out. Since I'm going to French polish, I also figure any nuance pores that didn't get filled, I'll pumice fill. The nice thing is that you can pumice fill at any stage of French polishing. (per MDP)
PostPosted: Fri Aug 13, 2010 4:50 pm
First name: Douglas
Last Name: Ingram
City: Lorette
State: Manitoba
The same problem that I have, every time, is that "Oh, no. Here we go again..." look from my wife when I start a new guitar.
http://redrivercanoe.ca/
PostPosted: Fri Aug 13, 2010 5:11 pm
First name: Big
Last Name: Jim
Crap , I didnt even think about that one ! laughing6-hehe
PostPosted: Fri Aug 13, 2010 5:53 pm
First name: James
Last Name: Bolan
City: Nashville
State: Tennessee
James if you have a small engineers square you can butt tha right up against your bone saw to get those cuts started square.As far as what haunts me .Nothing! It`s just too much darn fun.
James
James W Bolan
Nashville Tennessee
PostPosted: Fri Aug 13, 2010 6:47 pm
PostPosted: Fri Aug 13, 2010 7:45 pm
I don't understand. I never file a nut slot straight. In addition to angling the slot down about half the headstock angle, I always aim the rear of the slot toward the corresponding tuner post. They're never straight, and the back end is usually a little wider than the front end of the slot.
PostPosted: Sat Aug 14, 2010 1:11 am
Last Name: Abercrombie
Mike Baker wrote:
I don't understand. I never file a nut slot straight. I always aim the rear of the slot toward the corresponding tuner post.
Filippo Morelli wrote:
As for the nut slots not being straight, I angle them slightly toward the tuners ...
That's what I was thinking, too...That's the way I do mine.
[:Y:]
It would be easier to make the slots straight (square to the nut) but is that the best way?
idunno
PostPosted: Sat Aug 14, 2010 7:02 am
First name: Woodrow
Last Name: Brackett
City: Grover
Zip/Postal Code: 28073
I'm too self conscious to post what I can never get right wow7-eyes wow7-eyes wow7-eyes
But no one ever gets everything right. beehive beehive beehive
PostPosted: Sat Aug 14, 2010 8:28 pm
City: Tucson
State: AZ
Can never seem to get mah dadgum rim assemblies straight, the blocks are never in line with each other like they should be.....
PostPosted: Sun Aug 15, 2010 9:13 pm
For every error I correct, I move on to make a new one on the next build. It's an error-correcting lifetime :)
Ken Mitchell
Durham, NC
PostPosted: Tue Aug 17, 2010 3:16 pm
City: Tucson
State: AZ
Thanks for the suggestion Filippo but you've got the wrong dimensions in mind. When looking at the rim assembly from the top of the instrument the neck block and tail block aren't in line with each other, so picture a line running down the length of the instrument and the neck block is to the left of the center and the tail block to the right or vice versa. Going to try putting solid linings on before I attatch the sides. If the sides themselves are congruent to each other and I mount them correctly on the blocks I should get them straight. Also trying a new mold so we'll see how that goes. Hopefully I don't encounter many more problems after this is fixed.
Users browsing this forum: DennisK, jfrench79 and 41 guests
