It is currently Tue Aug 19, 2025 12:31 am
 Post subject: Woolson Neck Jig Plans
PostPosted: Sun Sep 19, 2010 3:04 pm
First name: jim
Last Name: mccarthy
City: ojai
State: ca
Zip/Postal Code: 93023
There are no instructions how this thing is used once assembled. Actually, in my opinion, the plans are not clear as far as assembly goes either.
Is there information on it somewhere here or on some other website? I couldn't find any.
PostPosted: Sun Sep 19, 2010 3:49 pm
Same feeling here. I bought a set of plans a couple of years ago, never having seen it used or found any info on it, it never got built. Now that I've got and used the Simpson jig it would probably make more sense to me.
Joe
PostPosted: Mon Sep 20, 2010 7:49 am
Same here, a little criptic. Probably makes total sense to Paul. After staring at it a while, I've pretty much figured it out, but will probably not make it exactly the same anyway.
PostPosted: Mon Sep 20, 2010 9:14 am
Somewhere there is a thread that goes through how to use this in some detail. The evolution of these plans were that after seeing the thread many asked if plans were available. That was the spark that got the plans drawn up. So taken out of context it is not surprising they are a little cryptic.
In truth though, the jig is pretty easy to use. It took me about an hour to get everything aligned the first time I used it and after that it was a very simple process to cut the tenons and be very close on the neck angle. Once the jig is set up well it only takes a few minutes to dial everything in and cut.
I will dig a little this evening to see if I can find that original thread.
PostPosted: Mon Sep 20, 2010 7:46 pm
First name: jim
Last Name: mccarthy
City: ojai
State: ca
Thank you Brock. I looked and couldn't find anything.
PostPosted: Wed Sep 22, 2010 2:49 pm
First name: Bobby
Last Name: Masten
City: The Woodlands
Zip/Postal Code: 77380
Just got my plans today and also interested if you can find the old thread.
Bobby Masten
PostPosted: Wed Sep 22, 2010 8:45 pm
Last Name: Shanklin
City: Windsor
State: ON
If you can follow the plans and build it, then it becomes self explanatory on how to use it. You can also view Jon Simpson's video on his jig. They work very similar.
Bob
Users browsing this forum: kyle.medeiros and 22 guests
