It is currently Tue Aug 19, 2025 8:50 am
PostPosted: Mon Oct 25, 2010 9:36 am
First name: David
Last Name: Mrozinski
City: Essexville
Zip/Postal Code: 48732
I have a nice set of black walnut back and sides, spruce top and black walnut neck. I plan to use rosewood fretboard, bridge and headstock veneer. What would be a good suggestion for binding. My first thought was ebony or black ABS for the body with some BWBW purfing on the top.
This is only my second build, so I am looking for some other thoughts on the binding.
Thanks for the help.
PostPosted: Mon Oct 25, 2010 10:29 am
First name: Daniel
Last Name: Minard
City: Powell River
State: BC
+1 on the curly maple. Looks great with almost any combination of woods.
PostPosted: Mon Oct 25, 2010 10:31 am
African blackwood .. the new ebony for me ....
PostPosted: Mon Oct 25, 2010 10:54 am
What did you do for the rosette? If wood, then you could match that.
Also, you could go with walnut to match the b/s with a single maple side perfling between them, that's always a classy look.
I also like curly maple.....decisions, decisions......
PostPosted: Mon Oct 25, 2010 10:57 am
Lacewood is also a good option. Not as light as Maple, but a good contrast with some character. Get a couple of extra pieces. It likes to break when bending.
PostPosted: Mon Oct 25, 2010 12:05 pm
I think "stealth" binding can be a nice look, using offcuts from your side wood for binding. I did this on a granadillo body and it looked quite nice and subtle. (Sadly, had to disassemble that box due to humidity issues). You could add side purfling to make it less stealthy.
Maple would probably look great if you like a dramatic contrast. Something like koa or mahogany might provide a little less of a stark contrast, depending on your tastes. I've always thought koa on dark rosewood was a classy look, might be similar on your walnut.
PostPosted: Mon Oct 25, 2010 12:48 pm
Another vote for curly maple. I just finished a Black Walnut/Engleman that has Curly Maple binding and I'm very happy with it.
Acacia is nice too.
Neil
PostPosted: Mon Oct 25, 2010 4:37 pm
Last Name: Kincheloe
Another vote for koa. Curly, to make it more eye-catching without such overwhelming contrast as maple. Could glue on a strip of maple for side purfling to make it more striking, and matching maple purfling around the back and fingerboard. Maybe add a strip of rosewood as well on the fingerboard, so you have koa binding, rosewood, maple, then rosewood of the fingerboard. Top purfling... probably black-maple-black, or maybe rosewood instead of the black. Or koa binding, rosewood, maple, black, then spruce of the top? Unnoticeable from a distance, but a "softer" look up close, while retaining the sharp contrast of black to the top wood.
If you're doing a center strip inlay in the back, I'd say rosewood with maple strips up the sides, or maybe maple-black-maple strips to make it more fancy. Always fine to do a backstrip matching the binding too though.
End wedge, I see 2 best options. Curly koa, or rosewood. If there is side purfling, rosewood would be easier, as you could just glue some maple strips to the sides of it and let it be fully bordered by maple. Koa would look beter if it's in contact with the binding, and side purfling miters around it. I'd most likely do the rosewood if I was doing a rosewood backstrip, koa otherwise.
PostPosted: Wed Oct 27, 2010 3:26 am
First name: William
Last Name: Stewart
City: Hawick
State: Roxburghshire
Zip/Postal Code: TD9 9NB
Country: Scotland
How about snakewood? I intend to use this on my next build although the b/s are English marbled walnut... should look interesting.
Bill S.
Dream to be a luthier
