It is currently Wed Aug 20, 2025 8:16 pm
 Post subject: Classical intonation
PostPosted: Thu Feb 10, 2011 6:44 am
First name: Martin
Last Name: Edwards
Hi troops,
I've used the search function and not really got my answer.....
I'm retopping an old classical which I was given as scrap. my 12 yearold fancies it as the plywood back and sides are admittedly gorgeous....
anyway, I have the top braced & fitted and a bridge made but not yet attached.
so. after nearly 70 steelstring instruments, I'm pretty much up to speed on intonation on those things, but nylon?
not a clue.
any classicals I've seen pics of, (never been near a really good one) it LOOKS like the bridge is parallel to the nut with no compensation other than maybe some shaping of the saddle, but certainly no slope like I'd expect on a steel string.
so, can someone please confirm or deny this?
SHOULD the saddle be sloped or straight?
thanks!
 Post subject: Re: Classical intonation
PostPosted: Thu Feb 10, 2011 7:09 am
Hi Martin,
Yes, the bridge and saddle are parallel to the nut. Compensation is normally done by locating the saddle a bit farther from the nut than the nominal scale length. On classicals with 650 mm scale this is about 2 mm. On flamencos usually about 0.7 mm. There are string by string intonation schemes that vary each string length slightly by filing "steps" into the front of the saddle. Some also do similarly at the nut, but these are not an absolute requirement for most classical builders/players. Perhaps some of our more experienced builders will weigh in on this somewhat esoteric subject.
good luck,
Max
Max Bishop
Brighton, Michigan
PostPosted: Thu Feb 10, 2011 8:25 am
First name: Jim
Last Name: Kirby
Saddle parallel to nut with 2 mm compensation is pretty standard. You can have more room to play with saddle shaping if you go to a 3+ mm saddle slot width, rather than a more standard 2mm width, but the slot itself is still usually parallel to the nut.
For the more involved approach aimed at doing fine adjustments, a good place to start is Greg Byers' article from American Luthiery - link here:
www.byersguitars.com/Research/intonation.pdf
Jim Kirby
kirby@udel.edu
PostPosted: Thu Feb 10, 2011 9:27 am
First name: David
Last Name: LaPlante
Here's my set set up as a for instance:
Saddle is about 2.5 mm and the E and D strings are set to 652mm as described above.
angled ramping provides a little additional compensation for the slightly more massive strings.
PostPosted: Thu Feb 10, 2011 4:27 pm
First name: Martin
Last Name: Edwards
thanks folks, straight it is!
Users browsing this forum: Chris Ensor, Darrel Friesen, DennisK and 25 guests
