It is currently Thu Aug 21, 2025 10:43 am
PostPosted: Mon Mar 21, 2011 8:26 am
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
Zip/Postal Code: 64081
Planning to use robbie o/brien/s M&T plans to build my 1 st OM guitar. I don/t want to make the templates myself . Checked stew mac and found a set for 76$ . Have any of you used the LMI or stew-mac templates ? and if so, what is your experience ?/ which one would you recommend for purchasing. I already have most of the hardware for the robbie o/brien plan ?? Thanks.
PostPosted: Mon Mar 21, 2011 4:48 pm
First name: Stephen
Last Name: Foss
State: Colorado
Ernie,
I've used and watch others use Robbie's M/T jig. When I made mine I made my own templates. I got the job done, but it was a lotta fiddling around to get it just right.
Robbie says that LMII will soon be offering a kit with all the hardware including both a set of M/T and dovetail templates. If you can hold out until LMII gets this ready, it's what I would suggest.
PostPosted: Mon Mar 21, 2011 5:26 pm
waldron guitars has some of the best templates I have seen yet .
PostPosted: Mon Mar 21, 2011 5:55 pm
First name: Dan
Last Name: Pennington
City: Brooklyn Park
State: MN
Zip/Postal Code: 55428
Ernie
How many OM's do you plan to make? Do you really need to spend the money for a template? Or if you plan to make your own template, do you really need to spend the time transferring dimensions from the plans to the template material and cutting it out. Then using the template to mark the wood.
Why not copy the layout from the plans right to the guitar wood itself. Save some time and money. And if you're off 1/32nd or 1/16th, big deal. You'll never be able to hear that in the finished guitar.
There! I said it and I'm glad.
PostPosted: Mon Mar 21, 2011 6:11 pm
Last Name: Fifield
City: San Jose
Zip/Postal Code: 95124
If you want the ultimate neck joint making tool, take a look at this system:
http://www.luthiertool.com/neck%20angle.html
Not inexpensive, but well worth the $$ IMO.
Cheers,
Dave F.
Cambrian Guitars
PostPosted: Mon Mar 21, 2011 6:33 pm
First name: Dan
City: Brooklyn Park
State: MN
Ernie
I misread your original post and thought you were talking about templates for bracing. My error. Sorry. Please disregard my rant.
Dan
PostPosted: Mon Mar 21, 2011 7:06 pm
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
I plan to use the mortise and tenon templates for 3 styles of gtr, steel string ,parlour,OM an dread. I looked at waldron , and found it extremely confusing to navigate through . I am a computer bozo though soooo .I looked at stew- mac. No responses so far about stew- mac. I like robbies design. I checked LMI . ,Will they be just selling the acrylic templates?? I already have the hardware, and baltic birch. I am redoing an old LMI alum . classical gtr template . Thanks for ideas , they are much appreciated, ernie
PostPosted: Mon Mar 21, 2011 9:41 pm
First name: wes
Last Name: Lewis
City: Garland
State: Tx.
Zip/Postal Code: 75044
there is also the simpson jig it comes with templates
MK5acoustics.com
PostPosted: Tue Mar 22, 2011 1:24 pm
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
thanks ordered the simpson jig. Anyone want to buy robbie o/briens jig plans. ??
PostPosted: Thu Mar 24, 2011 4:14 pm
First name: Tom
Last Name: Dl
You can print an OM plan out full size on a laser printer. Either go to a reprographics place, or assemble it. You can then use heat or transfer liquid to directly transfer the printed pattern to whatever you want. Plastic, metal, or wood. Not sure how that helps you, but it might. Another method that is really accurate is to use carbon paper and a pizza cutter.
