It is currently Thu Aug 21, 2025 10:30 pm
PostPosted: Sun Apr 10, 2011 4:13 pm
First name: Ron
Last Name: Y
The guitar is a Silver Creek which is a inexpensive all solid wood guitar. I'm not too concerned about an invisible repair, I just want to stabalze the crack. The crack is on the left side of the green tape in the first picture, and south of the green tape in the second picture. Any help would be appreciated. Thanks.
-Ron
PostPosted: Sun Apr 10, 2011 8:40 pm
First name: Ron
Last Name: Y
Hi Todd,
I hope all is well. Those are very good tips that you shared. Thank you.
PostPosted: Sun Apr 10, 2011 8:47 pm
First name: Ron
Last Name: Y
Hi Todd,
Where can I buy the micropipette?
Ron m.
PostPosted: Sun Apr 10, 2011 10:27 pm
First name: nick
Last Name: fullerton
City: Vallejo
State: ca
Zip/Postal Code: 94590
how do you apply CA glue like french polish? :?:
PostPosted: Sun Apr 10, 2011 11:07 pm
First name: Ron
Last Name: Y
Todd Stock wrote:
I buy micro-pipettes by the 5000 for about $12...should be a thread from a few months back covering the link to Biologix.
Cut up paper towels into 2" squares, fold to desired width, dip in thin cap and glide the pad on to the surface...each will be good for at least one pass, and sometimes two. Allow each layer to cure, then pad on another layer. Once there is enough CA on the surface, scrape and sand level, let sit overnight, then buff. This works on almost any polyester or poly urethane guitar finish...if the CA is hard, you'll avoid witness lines as well.
The crack seems to be level, so I'll try the CA method. Thanks Todd,
-Ron
PostPosted: Mon Apr 11, 2011 10:11 pm
First name: Ron
Last Name: Y
Todd,
The local Hobby shop has thin CA. Is that the same as "Medium thin"?
PostPosted: Mon Apr 11, 2011 10:52 pm
First name: Ron
Last Name: Y
Thanks Todd
