It is currently Fri Nov 29, 2024 4:44 am
 Post subject: Bandsaw Blade
PostPosted: Fri Jan 18, 2019 1:08 pm
First name: Joey
Last Name: Holliday
City: Palmetto
Zip/Postal Code: 34221
I have a 19" Grizzly 0514X2 that I mostly use for re-saw and simple straight cuts. I recently broke my Woodmaster CT when a wheel tire snapped and sent the blade off the saw and I haven't really needed to replace it yet. However, I find myself wanting to cut tight curves lately and would like to get a narrow, thin kerf blade capable of of doing so (neck blanks ect). Any recommendations?
Joey
 Post subject: Re: Bandsaw Blade
PostPosted: Fri Jan 18, 2019 5:06 pm
I don't have a bandsaw anymore, but when I did, I used a 1/4" 6 tpi blade a lot. Very versatile.
These users thanked the author Carey for the post: fingerstyle1978 (Fri Jan 18, 2019 9:30 pm)
PostPosted: Fri Jan 18, 2019 5:20 pm
Last Name: Gleason
City: Kurtistown
State: Hawaii
Zip/Postal Code: 96760
For those curves you'll most likely want 1/4" or maybe 3/8". I most often use 1/4" 4TPI for tighter curves or 3/8" x 3TPI for more gentle curves. In thick wood, If you go for more TPI like 6 or more, you will get a smoother cut, but a lot less blade life. If you plan on doing this for a long time, learn to make your own blades from coil stock. You'll save a lot of money and it's easy. Videos and coil stock are on line and brazing kits are in the catalogs Most woodworkers keep using a dull blade until it breaks or does nothing but burn through the cut. When you make your own blades, and always have some sharp ones hanging on the wall, you will find yourself changing to a new blade more often and your work will be better. IMO.--Bob
“ The meaning of life is to find your gift and the purpose of life is to give it away” Pablo Picasso
These users thanked the author Pegasusguitars for the post (total 2): Pmaj7 (Sat Jan 19, 2019 6:33 am) • fingerstyle1978 (Fri Jan 18, 2019 9:30 pm)
PostPosted: Fri Jan 18, 2019 11:09 pm
For cutting curves in thick stock I like to use a 1/4 inch 3 tpi skip tooth blade. The additional space between the teeth allows the sawdust to be carried away better so the blade lasts longer. For thin stock the 6 tpi would be better
These users thanked the author Clay S. for the post: fingerstyle1978 (Sat Jan 19, 2019 11:00 am)
PostPosted: Sat Jan 19, 2019 7:43 am
First name: Kevin
Last Name: Looker
City: Worthington
State: OH
Zip/Postal Code: 43085
+1 on the 3 TPI skip blade.
They require more feed pressure because they self feed less than a hook tooth . I’m able to cut smoother curves with a skip tooth but YMMV.
I'm not a luthier.
These users thanked the author klooker for the post: fingerstyle1978 (Sat Jan 19, 2019 11:00 am)
PostPosted: Sat Jan 19, 2019 9:00 pm
I used a Timberwolf/Viking 1/4" blade 3 tpi last week to cut some necks. Works just fine.
Brent
PostPosted: Tue Jan 22, 2019 8:16 am
First name: Ernest
Last Name: Kleinman
City: Guthrie
Zip/Postal Code: 73044
Check out bandsaw blade express in Pevely MO. excellent blades at reasonable prices. After I broke my CT blade twice figured it was not worth the $140 . Can get a whole bunch of blades for that price and sharpen them with a dremel and mini grinding stone as needed.
Users browsing this forum: No registered users and 59 guests
