It is currently Fri Nov 29, 2024 4:34 am
 Post subject: Re: Number 16
PostPosted: Thu Jan 24, 2019 9:59 am
First name: Casey
Last Name: Cochran
City: Gainesville
State: GA
Zip/Postal Code: 30501
sdsollod wrote:
That is a beauty Casey! How did you do the end wedge? Also, what gives the neck the dark look, is it a dark pore fill, stain, or perhaps a walnut neck?
I engraved the end wedge after the body was assembled and filled the engraving with a lacquer stick, available from Brownell's. The neck is stained Honduran Mahogany.
Good judgement comes from experience. Experience comes from poor judgement.
PostPosted: Thu Jan 24, 2019 8:12 pm
Last Name: Sollod
That is awesome! You must have masked off your rosette before you sprayed the sunburst. How did you do it?
www.swiftcreekguitars.com
PostPosted: Fri Jan 25, 2019 7:32 am
First name: Casey
Last Name: Cochran
City: Gainesville
State: GA
3M fine line tape, available at automotive paint and body supply shops. I brush lacquer onto the rosette and purflings after spraying the burst to level it up. I also have to brush some color onto the edge of the sound hole to even things up.
PostPosted: Fri Jan 25, 2019 10:40 am
Last Name: Sollod
I have used fine line tape to mask off a rosette, but found that the tape wanted to wrinkle as it made the turns around the rosette. I got it to work, but it was a little problematic...
PostPosted: Sun Jan 27, 2019 1:12 pm
First name: Patrick
Last Name: Hanna
State: Missouri
I haven't clicked in for quite some time. What a beautiful instrument to find on my first day back!
PostPosted: Sun Jan 27, 2019 2:14 pm
"I have used fine line tape to mask off a rosette, but found that the tape wanted to wrinkle as it made the turns around the rosette. I got it to work, but it was a little problematic..."
Rather than bending the tape around the rosette you can mask it with straight strips of cellophane tape and cut around the edge with a razor blade.
Users browsing this forum: No registered users and 61 guests
