It is currently Mon Feb 17, 2025 2:44 pm
PostPosted: Wed Sep 30, 2020 2:42 am
Well more guitar distortion really.
Just checked the intonation on a 2 year old build.
I was quite fussy setting this up originally, used a good tuner.
Just checked it again yesterday, same tuner. and had to move the break points on the saddle back ~1 mm to get the intonation acceptably.
Reset action and relief to original specs.
No sign of cold creep/movement at the bridge.
How much do your builds move??.
PostPosted: Wed Sep 30, 2020 9:39 am
It's hard to say how much - I've never really measured. I will say I have had to adjust the necks on some lightly built instruments to lower the action, because I didn't want to lower the saddle. Being "bolt ons" this was relatively painless.
Two things I do now - less perimeter sanding and (almost unconsciously) over compensate the saddle slightly. When I sanded the perimeter to where I felt I was getting an extremely responsive plate the top would pull up enough over a few months to require resetting the action. I still use my fingertips to feel how the soundboard is reacting to various frequencies, but accept less forceful responses. I will also accept the 12th fret fundamental being a - little - flat initially - the overtones are going a little sharp anyway, and as you noticed, it is more likely the string will go sharp than go flatter.
So I tend to build a little "heavier" than I used to and leave more wood in the plates.
These users thanked the author Clay S. for the post: roby (Wed Sep 30, 2020 1:55 pm)
PostPosted: Wed Sep 30, 2020 10:37 am
Last Name: Kincheloe
If the neck comes off easily, see if there are indentations in the soundboard binding where the heel cheeks push into it. That's one of the reasons I dislike bolt-on necks.
PostPosted: Wed Sep 30, 2020 11:32 am
Last Name: Gramann
City: Fredericksburg
State: VA
Zip/Postal Code: 22408
On my acoustics, I don’t do final setup until 2 months after I first string it up. The action sometimes raises as much as 3/64” due to a combination of truss rod settlement and bridge belly. I had one come back after 5 years where I had to fill and recut the saddle slot to restore intonation because the bridge had rotated a bit and the saddle was tilting slightly. That’s the price of a light build.
PostPosted: Wed Sep 30, 2020 12:36 pm
City: Vancouver
Any bridge roll? 1mm ain’t a lot of rotation...
PostPosted: Wed Sep 30, 2020 3:08 pm
My guitar making teacher used to say that he never heard of a guitar getting longer as it aged.
These users thanked the author Alan Carruth for the post (total 4): Pmaj7 (Fri Oct 02, 2020 8:17 am) • bcombs510 (Wed Sep 30, 2020 3:38 pm) • Michaeldc (Wed Sep 30, 2020 3:16 pm) • Colin North (Wed Sep 30, 2020 3:11 pm)
PostPosted: Tue Oct 06, 2020 12:18 pm
State: West Somerset
Country: UK
Apologies for restarting the thread...
Colin that does seem quite a lot of shrinkage. I've just checked and G&G allow only .5 of a mm for body compression in their bridge placement calc.
A falcate braced one I have been able to check after some months hadn't moved at all.
Do you know how soon after stringing up you did the intonation?
Dave M
PostPosted: Tue Oct 06, 2020 12:53 pm
First time only a few days.
Users browsing this forum: No registered users and 53 guests
