It is currently Thu Nov 28, 2024 1:50 am
Post new topic Reply to topic  [ 60 posts ]  Go to page Previous  1, 2, 3
PostPosted: Fri Oct 09, 2020 2:52 pm
Last Name: Gramann
City: Fredericksburg
State: VA
Zip/Postal Code: 22408
My new buffer is still in the box while I’m waiting for the lacquer to cure. What about putting the buffer in the clamp and holding the body? Would it be likely to throw the the guitar? I never went to the standard buffer discs that most folks use because I was sure it would throw the body given my coordination.
PostPosted: Fri Oct 09, 2020 2:57 pm
Last Name: Ball
Barry Daniels wrote:
Honestly, I had forgotten about my earlier trepidation about the weight because in use it became a non-issue and more of an assistance. I hope it works out that way for Bob.
Yeah, a vacuum clamp would be ideal for this. Which one do you have Dave?
I have the LMI clamp (I liked the clamp but I didn't like the Panavise mount, so I mounted it on a ball type carving vise. Much better) , as well as a slew of home made ones. I do CNC work, and you can never have too many fixtures! But for this application, it was the LMI.
PostPosted: Fri Oct 09, 2020 6:02 pm
That would never work. You want the buffing pads to move freely over the body in a set pattern. I divide the top or back into quadrants and do one at a time. Apply more compound when starting a new quadrant. Make overlapping passes first going one direction then going the other way. Move the machine fairly slowly. I watched some auto detail pros on youtube to see how they move the machine fairly slow.
PostPosted: Fri Oct 09, 2020 7:32 pm
Last Name: Gramann
State: VA
Thank you, Barry. That saved me some experimentation.
PostPosted: Fri Oct 09, 2020 9:00 pm
Also, remember to apply some pressure and use a slower speed at first. Then when the compound starts to break down and turn clear, lighten up on the pressure and maybe turn the speed up. Quit buffing the area when the compound largely disappears. This whole process may take 2 or 3 minutes in each quadrant.
PostPosted: Tue Oct 13, 2020 8:47 am
First name: Terry
Hey guys, has anyone tried "Varathan Ultimate" on an acoustic? Friend of mine is using it on Basses and is happy with the results.
The cure time is dramatically faster than what I'm using now. I'm also hopeful the buffing time might be less?
PostPosted: Tue Oct 13, 2020 2:41 pm
That little buffer will never throw an instrument. Now buffing wheels, that is a different story.
One thing I have learned about finish sanding is that when you think you are through with one grit, you are really only half done.
Yeah but then that's usually when I burn through the finish :(
Pegasusguitars wrote:
Yep, If memory serves, I've thrown 3 instruments in my 40+ on the buffer. Everything goes very calm and quiet when that happens. Turn off the buffer, and settle myself before looking at the carnage. Ukes travel farther than guitars, so with ukes one hopes there is no collateral damage. Time to summon my innermost sense of self control. That's not really a skill that one wants to get enough experience to highly develop, but the longer you make instruments the easer it gets. There are so many interesting ways to ruin a day in the shop! Hope I'm totally alone on this one!
LOL ukes go farther then guitars. I think you need to work in a padded cell :D
PostPosted: Wed Oct 14, 2020 3:38 pm
First name: Carl
Last Name: Dickinson
City: Forest Ranch
Zip/Postal Code: 95942
The Adams polisher is $108 today for Amazon Prime Day.
PostPosted: Wed Oct 21, 2020 8:53 pm
Last Name: Gramann
State: VA
Alright, I polished with my new polisher today. It took me about the same amount of time as it used to take me to do it by hand, but I now have the shiniest guitar I’ve ever made. And, that will only improve as I learn. I think this is a good path for me. I used my homemade vacuum clamp to hold the body while I polished the top and back. The polisher was a lot easier to use with two hands. Doing the sides with one hand in the guitar and one on the polisher was not difficult, but I may make another vacuum clamp for that orientation. I will be able to do a better job with two hands to support and control the polisher. My hands did know that they were holding a heavy vibrating thing for an hour.
Thank you, Barry. This is an improvement for me.
PostPosted: Thu Oct 22, 2020 9:40 am
Glad it worked out for you Bob.
I wanted to post this link again for people using this buffer. The machine is only part of the equation. Pads and compounds are the other half. One thing I see people here missing is the use of 4" diameter pads on this machine. That will make your work a lot easier. Also, using a FIRM pad with cutting compound will make the first step go quicker.
For a full description look at this thread over on the MIMF. The relevant detail is in the 12 post down.
https://www.mimf.com/phpbb/viewtopic.php?f=13&t=6117&p=59619&hilit=adams#p59619
Users browsing this forum: doncaparker and 35 guests
cron
