It is currently Sun Nov 24, 2024 5:26 am
 Post subject: Neck Sanding technique
PostPosted: Mon Jan 11, 2021 2:59 pm
Hi,
Is it just me or i always get problems sanding the heel transition. I have added a picture of the problem are circled in red, the blue arrows show the directions I'm sanding and those sections clean up nicely. Its just that transition thats cloudy
Anything I'm doing wrong please?
Sent from my SM-A715F using Tapatalk
PostPosted: Mon Jan 11, 2021 3:09 pm
First name: Toonces
Last Name: the Cat
City: New Smyrna Beach
State: FL
All that matters is whether the scratches will disappear under the finish. Sand to 320grit and then wet with solvent and see how it looks -- you shouldn't see any scratches. If you do, then keep sanding until they disappear. Usually the grain will look scratched or "cloudy" in certain locations but it just doesn't matter so long as it will look good once the finish is applied.
It doesn't matter which direction you sand the endgrain but I usually try to have my final passes with 320 go from the neck and up the heel. I almost always have to come back and address a couple spots to remove deeper scratches that didn't get removed when going through the grits. Don't stop at 220grit tho' -- I've found that isn't fine enough to remove scratches that may be visible under finish.
These users thanked the author Toonces for the post (total 2): Pmaj7 (Fri Jan 15, 2021 12:40 am) • cablepuller1 (Mon Jan 11, 2021 4:05 pm)
PostPosted: Mon Jan 11, 2021 3:24 pm
Online
Last Name: Kincheloe
If you shellac it and then continue refining, it will go more easily than on bare wood. But depending on your finishing process, you may need to keep it bare. Z-poxy would probably do the trick too, although I haven't used it myself. Just something to lock the endgrain fibers in place while you sand/scrape them.
These users thanked the author DennisK for the post (total 3): Pmaj7 (Fri Jan 15, 2021 12:42 am) • cablepuller1 (Mon Jan 11, 2021 4:06 pm) • Bryan Bear (Mon Jan 11, 2021 3:32 pm)
PostPosted: Mon Jan 11, 2021 3:47 pm
I also like wiping some shellac on as long as your finish process is compatible.
Sent from my SM-G970U using Tapatalk
These users thanked the author SteveSmith for the post: cablepuller1 (Mon Jan 11, 2021 4:06 pm)
PostPosted: Mon Jan 11, 2021 4:01 pm
First name: Terry
Keep in mind my necks don't have that radical of a transition, but what do you mean by "cloudy?" it looks like the effect of light or dust from the pic. In any case, grain looks very different at different angles, so if you want a very dramatic transition and still want to avoid a difference in grain appearance, I would suggest sealing the grain well before finishing to avoid uneven absorption of material.
Scratches are, imho, a completely different issue to what I think you are describing, and something I don't see at all in that pic of your problem area.
These users thanked the author TerrenceMitchell for the post: cablepuller1 (Mon Jan 11, 2021 4:06 pm)
PostPosted: Mon Jan 11, 2021 4:05 pm
Last Name: Orr
Looks like dust in the end grain. As suggested seal with shellac before final sanding after brushing away excess dust.
These users thanked the author Bob Orr for the post: cablepuller1 (Mon Jan 11, 2021 4:22 pm)
PostPosted: Mon Jan 11, 2021 10:02 pm
After a tip from Addam Stark years ago I got a Porter Cable Speed Bloc 330 1/4 sheet sander.
https://www.amazon.com/PORTER-CABLE-330 ... op?ie=UTF8
The rounded area where the sandpaper wraps around the edges of the pad in the front and back are great for getting into curved transition areas both at the heel and headstock. It’s been a Godsend for me in getting final scratches out of these areas. It is a finish sander with a small orbit.
I usually use Naptha to reveal scratches. I always have to go back at least once or twice to get areas I thought I had covered. You have to blow out the area with compressed air first.
Last edited by Terence Kennedy on Tue Jan 12, 2021 10:03 am, edited 1 time in total.
These users thanked the author Terence Kennedy for the post (total 2): Pmaj7 (Fri Jan 15, 2021 12:44 am) • cablepuller1 (Tue Jan 12, 2021 2:41 am)
PostPosted: Tue Jan 12, 2021 8:18 am
I like to use Naptha too because shellac gums up paper. Also, try using a scraper there. That will get you below any scratched fast then you can finish off with paper.
These users thanked the author jfmckenna for the post: cablepuller1 (Tue Jan 12, 2021 11:48 am)
Users browsing this forum: Colin North and 20 guests
