It is currently Sun Nov 24, 2024 3:12 am
 Post subject: Inlay Material
PostPosted: Mon Mar 08, 2021 1:20 pm
First name: Corey
I'm still researching and setting up my first build, and I wanted to try a few different things. For the fretboard inlays, can they be a form of metal? Or will that interfere with the fretwire?
 Post subject: Re: Inlay Material
PostPosted: Mon Mar 08, 2021 2:19 pm
Do you mean like will it cause some corrosion or something? I don't think that would be a problem.
PostPosted: Mon Mar 08, 2021 2:22 pm
Last Name: Ball
I've inlaid metal on several banjos--nickel silver mostly, since it engraves nicely. It was pretty common in the late 19th century.
PostPosted: Mon Mar 08, 2021 4:05 pm
Nickel silver would be a good choice for inlays - it is relatively easy to cut, polishes up well and isn't too expensive as it contains no silver:
"Nickel silver, a range of alloys of copper, nickel, and zinc which are silvery in appearance but contain no silver. Its composition varies from 7 to 30 percent nickel, the alloy most widely used being 18 percent nickel silver (18 percent nickel, 62 percent copper, 20 percent zinc)." (britannica.com)
Many woodwind instruments use nickel silver for the keys.
https://www.amazon.com/Nickel-Silver-Sh ... B00F1OC1FM
PostPosted: Mon Mar 08, 2021 4:20 pm
First name: Tony
Last Name: Thatcher
City: Bozeman
State: MT
I've used knife handle mosaic pins and brass wire for side dots. Lots of variety and look great.Image
Sent from my SM-G973U using Tapatalk
Tony Thatcher
Bozeman, Montana
These users thanked the author mountain whimsy for the post: Skarsaune (Mon Mar 08, 2021 8:20 pm)
PostPosted: Mon Mar 08, 2021 4:31 pm
Last Name: Ball
Those do look good.
I've done side dots out of small brass tubing with colored epoxy in the middle--banjos frequently have colored veneers under the fingerboard, and I'd color the epoxy to match the veneer.
PostPosted: Mon Mar 08, 2021 4:37 pm
Last Name: Ball
Here's a resonator uke I built back in the 80s. Spun my own cones and everything back in those days. But the inlay at the end of the fingerboard is red epoxy in an aluminum tube. Sort of a bigger version of the side dots I've done out of metal,
PostPosted: Mon Mar 08, 2021 8:21 pm
First name: Chuck
Last Name: Skarsaune
City: Butler
I’ve got some mosaic pins in the bench for my current project.
PostPosted: Tue Mar 09, 2021 9:12 am
Last Name: Minch
City: Chestertown
Zip/Postal Code: 21620
I have used sterling silver and copper - under a finish they retain luster
Ed M
PostPosted: Tue Mar 09, 2021 11:07 am
I've used brass but it will tarnish, even under a finish. Aluminum is better because it looks like silver but will not tarnish.
PostPosted: Tue Mar 09, 2021 1:37 pm
First name: Corey
These mosaic pins were exactly what I was thinking about. I was a knifemaker and have a lot of materials left over including some of these pins. They also make ones called "Decrofil". They are brass/copper tubes filled with colored epoxy or phenolic. Give it a really nice look. Well thanks guys that definitely answered my question
PostPosted: Mon Mar 15, 2021 11:56 am
I have also seen powdered metals that can be mixed with epoxy to fill like inlay.
Users browsing this forum: No registered users and 40 guests
