It is currently Wed Nov 27, 2024 10:31 am
PostPosted: Wed Dec 08, 2021 11:03 am
So when you guys finally get to the level sanding and start to work up the through the grits to get to the buffing arbo stage of a build, provided you’re doing lacquer, do you do it by hand?
Do you use a small sander?
I’m open to upgrading this part of my building process …
Just curious as to what method you all like
PostPosted: Wed Dec 08, 2021 4:34 pm
I level sand by hand
PostPosted: Wed Dec 08, 2021 4:59 pm
Last Name: Gramann
City: Fredericksburg
State: VA
Zip/Postal Code: 22408
By hand with a 2” gum eraser as a sanding block.
PostPosted: Wed Dec 08, 2021 5:41 pm
I have a festool sander a 5 in, I get the paper with no holes from klingspore and micro mesh
PostPosted: Wed Dec 08, 2021 5:45 pm
Me too
These users thanked the author SteveSmith for the post: Bryan Bear (Wed Dec 08, 2021 11:07 pm)
PostPosted: Wed Dec 08, 2021 5:50 pm
Last Name: Parker
City: Charleston
State: West Virginia
Zip/Postal Code: 25314
I could use my Festool 5” random orbital sander, but I prefer going slower and playing it safe. I use small sanding blocks of varying rigidity. Maybe someday I’ll feel OK going faster.
PostPosted: Wed Dec 08, 2021 6:05 pm
Dig mistakes eraser here
PostPosted: Wed Dec 08, 2021 9:10 pm
The Festool 5” - great tool.
PostPosted: Thu Dec 09, 2021 6:27 am
there are big erasers at the dollar store for Big Mistakes also you can get the pipe insulation and make your own for the hand blocks
as for wet sanding a small squirt of dawn in a water bottle makes a good wet solution
PostPosted: Thu Dec 09, 2021 9:15 am
I’ve considered this tool… Simone said it was hard to control:/
Can’t be any harder than my Bosch Random orbit ha
PostPosted: Thu Dec 09, 2021 9:17 am
First name: Rob
Last Name: McDougall
City: Cochrane
State: Alberta
I also use big erasers to block sand, and a 6" piece of clear round gas-line hose as backing for the roundy bits....
For waterborne lacquers like EM6000, it is not recommended to wet-sand with water.
After dry sanding to P800, I wet sand with Wet & Dry with P1000, P1500, then P2000 using light mineral oil as wetting agent.
Old English Lemon Oil is simply light mineral oil with a lemony fragrance - works great.
After sanding to P2000, very little effort on the buffer is required to polish it out with no scratch marks.
These users thanked the author Robbie_McD for the post: Pmaj7 (Thu Dec 09, 2021 3:48 pm)
PostPosted: Thu Dec 09, 2021 2:49 pm
First name: Jay
Last Name: De Rocher
City: Bothell
State: Washington
Interesting. I wet sanded EM6000 with micromesh pads and water on six guitars and it worked fine. It was super, super tedious though so I switched to dry sanding but with 3M Gold Fre-cut sandpaper followed by Mirka Abralon pads (and switched to Endurovar).
These users thanked the author J De Rocher for the post: Pmaj7 (Thu Dec 09, 2021 3:50 pm)
PostPosted: Mon Dec 13, 2021 8:52 am
First name: Rob
City: Cochrane
State: Alberta
When I tried wet-sanding with W&D after dry-sanding with P800 3M Gold Fre-cut sandpaper, I experienced witness lines and even some film breakdown between layers (on a run of 5 guitars).
Very frustrating. The finish had cured for 14 days after the last spray session.
I scoured the Target forum and the consensus there was to avoid water, and use light mineral oil instead.
No problems since, and the process is no longer tedious...
PostPosted: Mon Dec 13, 2021 9:48 am
When I sprayed EM6000 I wet sanded with low-odor mineral spirits and had no problems.
These users thanked the author SteveSmith for the post: Robbie_McD (Tue Jan 04, 2022 8:41 am)
PostPosted: Mon Dec 13, 2021 10:31 am
For level sanding I will use an orbital sander for the "flat" areas but stay away from the edges. I will do the edges by hand. If wet sanding I will use a few drops of dish detergent in the water. I try not to remove any more finish than I have to, and will move through the first couple of grits before the surface is completely level (still see some shiny spots).
Users browsing this forum: No registered users and 57 guests
