It is currently Fri Sep 19, 2025 4:00 pm
PostPosted: Wed Jan 16, 2008 10:48 am
For those of you who use Adi bracing, what do you use for the back strip.  Do you make it out of extra Adi top material, or use a pre-made Sitka strip from someone like LMI.  I'm thinking that there may be a color issue using a Sitka strip with Adi bracing.
PostPosted: Wed Jan 16, 2008 11:39 am
I use adi from top trimmings
PostPosted: Wed Jan 16, 2008 12:51 pm
[QUOTE=zehley] For those of you who use Adi bracing, what do you use for the back strip.  Do you make it out of extra Adi top material, or use a pre-made Sitka strip from someone like LMI.  I'm thinking that there may be a color issue using a Sitka strip with Adi bracing.[/QUOTE]
there is no real reason you can't use sitka except visual
I often use sitka on the back, addy or sitka backstrip, but I always use addy on top bracing.
Sitka is pinker usually, can be almost white to tan.
Addy is generally more yellow, and can have red streaking which goes with most sitka well.
Basically, once they strum your guitar, they won't care one way or the other what you have in there!
Great question, welcome to the forum.
Users browsing this forum: Geocoucou79 and 27 guests
