It is currently Sat Sep 20, 2025 12:23 pm
 Post subject: bending tassie Blackwood
PostPosted: Thu Jan 31, 2008 3:27 pm
First name: Martin
Last Name: Edwards
I have a guy whos talking to me about building him a guitar.
we've gone through a bunch of wood options and its LOOKING like maybe Tassie Balckwood, & Port Oxford cedar, but noting is anywhere NEAR decided yet.
I've worked with EI Rosewood, Maple, Walnut, Leopardwood, Granadillo, Mahogany & Oak.
is TBW harder to bend than any of them?
I've never had any in my hands before.....
Thanks!!
PostPosted: Thu Jan 31, 2008 3:35 pm
Bends pretty much just like Koa 300F-310f. Like with any wood the figure may play a role but I never had an issue Black Acacia. (Tas Blackwood). One thing I will suggest is that you bend it with very little added moisture and wrapped in kraft paper as aluminum foil can react with resins and stain the wood a green. this will almost always sand out but not using foil will eliminate most of it but you so need a buffer like kraft paper between the wood and slats.
PostPosted: Thu Jan 31, 2008 3:38 pm
First name: Martin
Last Name: Edwards
okay.......
I've never bent Koa!! :oops:
He's talking about a Lowden sized Jumbo with a cutaway........
PostPosted: Thu Jan 31, 2008 3:58 pm
martinedwards wrote:
okay.......
OK then it will bend similar to bending something between Maple and IRW.
as far as the cutaway if the wood is figured you might want to use SuperSoftII a couple days in advance of the bend. It would not hurt to use it anyway
PostPosted: Thu Jan 31, 2008 4:00 pm
First name: Martin
Last Name: Edwards
cool, thanks!!
Users browsing this forum: Paul Burner and 14 guests
