Spiral Cutter head http://w-ww.luthiersforum.com/forum/viewtopic.php?f=10101&t=15823 |
Author: | Rich Schnee [ Sun Feb 10, 2008 4:04 pm ] |
Post subject: | Spiral Cutter head |
Grizzly makes an Industrial Spiral Cutter head (http://www.grizzly.com/products/h2879) Has anyone used one yet and how well does it work??? |
Author: | PaulK [ Sun Feb 10, 2008 5:34 pm ] |
Post subject: | Re: Spiral Cutter head |
Rich, Check out Byrd Tool. I noticed in the other thread you are interested in using one in your shaper, which they make for that use: http://www.byrdtool.com/SHELIX%20shaper.html The Shelix gives a true shear cut since the inserts are on an angle.I don't own one but have used the Shelix in a jointer...I want one. Paul |
Author: | PaulK [ Sun Feb 10, 2008 5:35 pm ] |
Author: | Chas Freeborn [ Sun Feb 10, 2008 5:55 pm ] |
I've got a 3" tall Shelix on order directly from Byrd. Should be here any day now. I'll let y'all know how it works on my 3 hp shaper. Some of the Grizzly cutters are made by Byrd. Not sure if the one you're looking at is. -C |
Author: | Sylvan [ Sun Feb 10, 2008 5:58 pm ] |
I have the Grizzly jointer with the spiral cutterhead. It is a terrific machine. No tearout at all when joining figured maple, etc., just a clean cut. Highly recommended! |
Author: | Terry Stowell [ Sun Feb 10, 2008 7:59 pm ] |
Hey Charles, I'd be interested in seeing what you do with your shaper, jigs, etc. I picked up a Grizzly 3 HP shaper recently, but haven't done anything with it yet... |
Author: | Terry Stowell [ Sat Feb 16, 2008 11:28 am ] |
Hey Charles, How's the new shelix working for you? |
Author: | Kent Chasson [ Sat Feb 16, 2008 1:17 pm ] |
Sylvan, (or anyone else who's used them) Have you rotated the cutters yet? How long do they stay sharp compared to HSS? Do they re-seat easily and accurately when you rotate them? Do you get any ridges? Thanks. |
Author: | Bob Garrish [ Sat Feb 16, 2008 1:47 pm ] |
I don't know about the particular cutterhead in this thread, but I haven't had to rotate the carbide knives in my General helical head jointer since I've been in business...at four sides, if I rotated them next week, that'd make six years life from a set! ![]() |
Author: | j.Brown [ Sat Feb 16, 2008 1:57 pm ] |
I've used the grizzly jointer with the spiral setup. Most beautiful cuts I've ever seen from a jointer. I was able to join tops and backs straight from the machine with no cleanup. Simply amazing. -j. |
Author: | Chas Freeborn [ Sat Feb 16, 2008 2:39 pm ] |
Shelix head arrived yesterday, and after a little modification to the spindle of my shaper is on the machine. Boy howdy is that a fearless cutter! Not for use by the faint of heart, inexperienced, intoxicated or otherwise impaired. I'm doing a run of necks now and taking pics along the way. I'll put 'em together for a slide show when I'm a little further along. -C |
Author: | Rich Schnee [ Sat Feb 16, 2008 4:03 pm ] |
I finally got over to my shop to measure my spindle capacity under the nut and its 4”. With a rub collar I would have to get the 3” cutter head and that would leave my short for what I want to do. My shaper is a three HP machine with an inch and a quarter spindles; you would think it would have a longer spindle. ![]() What size cutter heads are any of you guys using? |
Author: | Chas Freeborn [ Sat Feb 16, 2008 4:45 pm ] |
I had to put my spindle in the lathe and "lengthen" it about 1/4" to allow for the cutter and bearing. Not sure what operation (in guitarmaking) that requires more than a 3" tall cutter... You may be able to change the spindle to a longer one if need be. -C |
Author: | Rich Schnee [ Sat Feb 16, 2008 5:33 pm ] |
Chas Freeborn wrote: I had to put my spindle in the lathe and "lengthen" it about 1/4" to allow for the cutter and bearing. Not sure what operation (in guitarmaking) that requires more than a 3" tall cutter... You may be able to change the spindle to a longer one if need be. -C The heel on my acoustic necks are 4” tall and the width on the headstock 3 ¼”. What I would like to do is be able to shape the entire back profile of the neck in one pass. Then do the side profile. I might be able to recess the nut into the cutter head or just give the 3” cutter some more consideration. I wish the diameter was 3” instead of 4”. Looking forward to the slide show… |
Author: | Robbie O'Brien [ Sat Feb 16, 2008 9:42 pm ] |
I have used the spiral cutterheads on both the Grizzly joiners and planers. I love 'em. |
