InitialSetup...Electric Guitars http://w-ww.luthiersforum.com/forum/viewtopic.php?f=10101&t=16184 |
Author: | JJ Donohue [ Sat Mar 01, 2008 9:41 am ] |
Post subject: | InitialSetup...Electric Guitars |
I've just started the process on one and will be doing another in a month. I have a basic idea from having done acoustics but wanted to know the techniques and metrics of those builders and repair people who do a lot more. Are there any tried and true methods and are there any online publications that I can study and follow? TIA |
Author: | David Collins [ Sat Mar 01, 2008 12:27 pm ] |
Post subject: | Re: InitialSetup...Electric Guitars |
Are you more interested in hearing the process or specs? Simplified, I would say about the same as any setup. First truss rod, then nut, then saddle height, then checks and balances - meaning perhaps playing saddle height against truss rod back and forth. The fine tuning here can put you in different directions depending on variables like fret board radius, shape of neck relief, fall away, etc. If I remember right, is this for that shredder guitar? Depending on how level the frets are you can get pretty darn low for that style. |
Author: | JJ Donohue [ Sat Mar 01, 2008 12:40 pm ] |
That's the one, David. I just now cleaned the finish from the frets and started getting everything straight and level. The nut is still high and until those variables are addressed I won't even touch the saddles. I was hoping to be able to be able to hear about both process and specs that you guys shoot for on a Strat-type neck as well as a LP-type (which is the 2nd one that is currently in finishing). BTW, you will see Shredder next Saturday. I was hoping to get it through setup so that you wouldn't yell at me too much and that it could at least be played by Lance...our Hair Hand Extrordinairre Retro-Dude! |
Author: | Bruce Dickey [ Sat Mar 01, 2008 2:17 pm ] |
Years ago, back in "96, when I bought a Fender Stratocaster for my son, it came with a little Owner's Manual. That's all I needed to do an electric setup. http://www.frets.com for nuts and truss rods, which you already know anyway.... pics? tutorial? You know there's always a greenhorn out there somewhere.... |
Author: | Steve Kinnaird [ Sat Mar 01, 2008 10:55 pm ] |
JJ, the process I've used is to start off by setting the strings where they are just off the frets--the thickness of a playing card. Then lower gradually till they start to buzz. ![]() Steve |
Author: | Steve Kinnaird [ Sat Mar 01, 2008 10:59 pm ] |
Actually, JJ, you've gotten good advice already. Dan Erlewine likes a straight neck. Others want a hint of relief. Most players just want the lowest it will go. Do the best prep work you've ever done! You're already going to have an advantage in that you'll be using lighter gauge strings. Ask the player if he's a power chord guy, or a bend 'em and weep guy, or a chicken picker. Then get out that playing card and set it up. SK |
Author: | Billy T [ Sun Mar 02, 2008 1:46 am ] |
Steve Kinnaird wrote: JJ, the process I've used is to start off by setting the strings where they are just off the frets--the thickness of a playing card. Then lower gradually till they start to buzz. ![]() ![]() ![]() ![]() ![]() ![]() That's the way I do it! That way you know you're too low! EZ as Pi! Thanks Steve! Billy T |
