spring holders on side bender http://w-ww.luthiersforum.com/forum/viewtopic.php?f=10101&t=17573 |
Author: | Bill Higgs [ Wed Jun 11, 2008 6:49 pm ] |
Post subject: | spring holders on side bender |
Does anyone know what the little spring holders on the Everett Side Bender are called? If you do, do you know where I can get them? Bill Attachment: EverettSideBendingMachine.jpg
Author: | Bill Higgs [ Wed Jun 11, 2008 8:40 pm ] |
Post subject: | Re: spring holders on side bender |
Thanks Todd. |
Author: | Hesh [ Wed Jun 11, 2008 9:37 pm ] |
FYI too John Hall at Blues Creek also sells the cauls, springs and probably the hardware too. |
Author: | Mike OMelia [ Wed Jun 11, 2008 10:02 pm ] |
http://www.mcmaster.com Amazing site. And it will be on your door step lickity split. Never seen a company ship stuff so fast. Mike |
Author: | sdsollod [ Thu Jun 12, 2008 9:00 am ] |
I looked at the mcmaster site for the clamping wheel assemly at the top of the bender, but I don't know what its called. ![]() |
Author: | gozierdt [ Thu Jun 12, 2008 7:59 pm ] |
Steve, They have some listed under "stud knobs", under the "revolving Handles" title. I don't know if the studs are long enough for you. Another alternative is to get a "threaded hole handle" and cut a section of threaded rod to the right length, then use cyanoacrylate glue to hold the handle and rod together. |
Author: | Mike OMelia [ Thu Jun 12, 2008 10:39 pm ] |
This may be more appropriate for the Fox Bender, but Mcmaster lists something called a "press screw". Comes with the handle, screw, and base mount. The trick with Mcmaster is to know what to call it... two days later its on your doorstep. Might try their "express" delivery service... got be like "mouse click" and "ding dong" 2 minutes later. Mike |
Author: | gozierdt [ Fri Jun 13, 2008 10:34 am ] |
Grizzly also has a press screw available- I got one for my cutaway caul on the bender (first cutaway- next build). |
Author: | Wayne Clark [ Sat Jun 14, 2008 11:34 am ] |
Bill, You can also use mirror hangers to attach the springs. That's what I used on mine. You can get them at Home Despot. I got the press screw from Constantine's. Wayne |
