Need a source for this metal rod http://w-ww.luthiersforum.com/forum/viewtopic.php?f=10101&t=17594 |
Author: | Mike OMelia [ Fri Jun 13, 2008 7:59 pm ] |
Post subject: | Need a source for this metal rod |
I need a steel shaft, 3/4" diameter, 30-36" long. Each end needs to be turned down and tapped for a 1/2" nut. Tapping length on each end should be 2". Balance is important. I have looked around on the net, but not found what I want yet. mcmaster is too limited in their selection here. Mike |
Author: | wbergman [ Fri Jun 13, 2008 8:37 pm ] |
Post subject: | Re: Need a source for this metal rod |
Try the Yellow Pages for a machine shop. |
Author: | Dan Minard [ Fri Jun 13, 2008 10:08 pm ] |
Sounds like you're building a buffer... If so, some folks buy go-cart axles (don't know where from, but Google will help out.) I had mine turned by a machinist & it was quite a bit more expensive that the go cart axles I read about... On this forum IIRC. Try the archives, you might get lucky. |
Author: | Mike OMelia [ Sat Jun 14, 2008 10:02 am ] |
http://www.mfgsupply.com/m/c/AZ1401-36.html?id=bpMg5eIy Todd, you are a genius! ![]() This is EXACLTY what I need. Keyed, threaded, etc. I have something a bit more involved than just a buffer, but a buffer is part of it! Thanks!!! Mike |
Author: | Mike OMelia [ Sun Jun 15, 2008 10:06 pm ] |
Ya know, now that you mention it, I remember Dan talking about about the Go-Kart axle buffer. ITs amazing how expensive a part can be until someone finds a common use for it (Go-Kart axles). Then it is just a commodity. Mike (Thanks to Dan also) |
Author: | Steve Walden [ Mon Jun 16, 2008 2:34 pm ] |
I don't want to be a downer.....but with the full length keyway these shafts are essentially 3/4" diam or less. Can you buy them without the full length keyway? |
Author: | Kirt Myers [ Mon Jun 16, 2008 3:07 pm ] |
Here's another source, but they have full length keys also. http://www.northerntool.com/webapp/wcs/ ... +93+544613 |
Author: | Barry Daniels [ Tue Jun 17, 2008 2:47 pm ] |
A buffer should have one end with right-hand threads and the other with left-hand threads. This keeps the nuts from spinning off. |
Author: | TonyKarol [ Wed Jun 18, 2008 6:11 pm ] |
Although its been mentioned that a 3/4 shaft with the ends turned to 1/2 inch threads and 36 long doesnt work all that well (or at least wobbles) .. mine doesnt seem to. I run it with a 1/5 HP motor, and single 12 inch buff from SM at each end. I also do not have the left end left hand thread, but instead used nylon lock nuts to secure the buff(s). They havent budged in a couple years of use (about 25-30 guitars or so). Maybe not good enough for some, but I did mine in the cheap and pretty much couldnt be happier with its performance. With the 1/5 hp, it also bogs down if you really lay into it, so its kind of a no-think fail safe to avoid burning thru ... you never get too much pressure. |
Author: | Mike OMelia [ Wed Jun 18, 2008 9:47 pm ] |
WaldenWorx wrote: I don't want to be a downer.....but with the full length keyway these shafts are essentially 3/4" diam or less. Can you buy them without the full length keyway? How does a key way change the diameter? It is 1". Yes, I thought about the reverse thread thing. Mike |
Author: | TonyKarol [ Thu Jun 19, 2008 7:11 am ] |
he is talking about stiffness .. I can see it being less than a true 1 inch rod, but not to the point where it becomes 3/4 or less ... there is a huge difference in cross sectional area between 3/4 and 1 inch ... |
Author: | Mike OMelia [ Thu Jun 19, 2008 9:19 am ] |
OK, I have thought about the strength issue. It is true the shaft is keyed on BOTH sides. Here is some additional info. The center section +/- 7 inches will be "strenghened" with a 4" diameter wooden roller (keyed) and locked to the axle with locking hubs (google steel mini-hub). At +/- 10 inches, pillow block bearings will support the shaft. Locking shaft collars will hold the shaft in place. That leaves a little less than 8" hanging outside for the buffer wheels (may be a reason for going with a 40" shaft). All of this will be driven by a 3/4 to 1 hp motor, 1750 rpm, pully ratio 2.5:1. When using the sander, there will be no buffer wheels on the shaft (but it may not matter). What do you think? Mike |
Author: | Barry Daniels [ Thu Jun 19, 2008 9:59 am ] |
I would just start with a larger or partially keyed shaft instead of trying to add a splint to one. |
Author: | Mike OMelia [ Thu Jun 19, 2008 12:12 pm ] |
It is a single shaft... the roller is not a splint, but part of the overall design. Larger diameter (>1") go-kart axles do not appear to be available. This device will function as a thickness sander and as a buffer. The floor (sled) of the device rises up to (adjustable) to create thinner boards. Mike |
Author: | Mike OMelia [ Fri Jun 27, 2008 10:02 am ] |
I am looking for some 1" Diameter pillow block bearings... I found these: http://www.amazon.com/Buyers-Hydraulic- ... 151&sr=1-1 But, I am not sure what they mean by "hydraulic". The price is right... Mike |
Author: | David Collins [ Fri Jun 27, 2008 10:29 pm ] |
slackkey_mike wrote: This device will function as a thickness sander and as a buffer. This whole time, that's what I was afraid you were planning. Some people might do it, I've seen some run a giant disc sander and buffing wheel on the same shaft. Those people are %(#$ing crazy. Here's my advice. One very, very key feature that I think is imperative to any buffer I would use is low torque, low inertia (or is that two key features? ![]() I've seen dozens (not exagerating - literally dozens) of guitars, bodies, necks, shattered by being launched from an overpowered buffing wheel. My advice - these are two totally separate machines, with very different and very opposing priorities. Not good bed mates at all in my opinion. Disc sander at the end of a drum sander shaft? - now hat's a cool space saving idea. I sure wouldn't put a buffer there though. |
Author: | Mike OMelia [ Sat Jun 28, 2008 11:19 am ] |
I have decided against the design. I will make two separate fixtures. Mike |
Author: | David Collins [ Sat Jun 28, 2008 1:06 pm ] |
slackkey_mike wrote: I have decided against the design. I will make two separate fixtures. Mike I do apologize Mike - I hope you didn't take offense at what I said. I'm not out to bash anyone's ideas - it's just that I've worked on buffers that were way over-powered, and they really scare the crap out of me. ![]() Keep comin' with the ideas though. ![]() ![]() |
