Binding using a drill press
http://w-ww.luthiersforum.com/forum/viewtopic.php?f=10101&t=17722
Author:  ChuckH [ Tue Jun 24, 2008 10:53 am ]
Post subject:  Binding using a drill press
Has anyone used a drill press for binding? I wouldn't think a drill press would have enough RPM for the job. A drill press would keep the bit vertical also. One could make a table to hold the guitar level to rotate under the bit and lower and raise the chuck as needed. Try to fit a disc on the chuck for the bit to ride on the edge of the guitar.
Author:  Brock Poling [ Tue Jun 24, 2008 10:56 am ]
Post subject:  Re: Binding using a drill press
No, but I have built a jig to do what you are thinking.
It was a 2'x2' piece of MDF with a big "arm" that comes over it and suspends a lam trimmer. I put the LMI binding bit set in it and it works great.
I use it to bind carved top electrics. It cuts the channel an even distance from the "BACK" of the guitar and helps deal with the carved areas.
Works like a champ.
Author:  Barry Daniels [ Tue Jun 24, 2008 12:41 pm ]
A standard drill press has insufficient speed (rpm) for routing a clean cut.
Author:  ChuckH [ Tue Jun 24, 2008 1:50 pm ]
I kinda thought it wouldn't have.
Thanks Brock and Barry
Author:  Mike OMelia [ Tue Jun 24, 2008 2:14 pm ]
I just finished building my Williams Jig, can't wait to try it out.
