Would like blessings to some new tools I'm ordering
http://w-ww.luthiersforum.com/forum/viewtopic.php?f=10101&t=18051
Author:  SkyHigh [ Sun Jul 20, 2008 12:55 pm ]
Post subject:  Would like blessings to some new tools I'm ordering
As I'm getting close to closing my first box. I would like to get some tools that are needed in next steps.
Here are the things I'm thinking of and any honestly opinions or better subsitudes would be greatly appreciated. Trying to save on shipping so I would like to puchase not only for this build but for my next scractch build.
-Reamer from StewMac I don't know if I need 3 and 5 degrees or more.
-Gauged saws from StewMac
-LMII Bearing set
-Shaft adaptor from Stewmac
I need your recommendations as to which and from where:
-Nut files from Stewmac or Allied
-filler gauge
-Circle or/and Rosette cutter
Thanks, David
btw, I read the archives. I just would like fresh and updated info on some of these.
Author:  Howard Klepper [ Sun Jul 20, 2008 1:20 pm ]
Post subject:  Re: Would like blessings to some new tools I'm ordering
I had to look up the gauged saws. Looks to me like a solution in search of a problem. I just use a knife-edge needle file to start each slot.
Re nut files: you don't need one for every gauge. That knife edge needle file will do the two plain strings just fine. Others can cut a bigger slot if you massage them a bit while filing.
Reamer: you don't need both unless you are using both pin tapers.
Author:  SkyHigh [ Sun Jul 20, 2008 1:37 pm ]
Hi Todd,
.008 razer saw from stewmac?
Where do I get Wells-Karol micro-adjust circle cutter ?
Author:  Pat Foster [ Sun Jul 20, 2008 3:58 pm ]
SkyHigh wrote:
Hi Todd,
Build it! [:Y:]
Author:  rjeffery [ Sun Jul 20, 2008 4:33 pm ]
look into purchasing or making a grimal.
Author:  James Orr [ Sun Jul 20, 2008 4:37 pm ]
Sylvan made one of his circle cutters for me last fall. Using it with my PC 310 has made the process so simple. It might be my nicest tool.
Author:  joel Thompson [ Sun Jul 20, 2008 4:57 pm ]
Do you mean a gramil? or purfling cutter.
for cutting the purfling channel.
I agree it really helps to mark out the binding channel before routing.
Pilgrims prodjects are the cheapest i have found and they ship quite promptly
Joel.
Author:  Pat Foster [ Sun Jul 20, 2008 4:59 pm ]
Pat Foster wrote:
SkyHigh wrote:
Hi Todd,
Build it! [:Y:]
Here's some pics of the one I built, loosely based on Sylvan and Tony's. I used acrylic, but I think it was Todd who's had this material shatter on him while working it. He has suggested Lexan or Delring, if I recall.
http://patfosterguitars.com/circlejig/index.html
