Claro Walnut Dust Contaminating Spruce Top? http://w-ww.luthiersforum.com/forum/viewtopic.php?f=10101&t=18120 |
Author: | Ron M. [ Fri Jul 25, 2008 2:22 pm ] |
Post subject: | Claro Walnut Dust Contaminating Spruce Top? |
Should i apply a coat of shellac to the top to protect It from walnut dust? Should I be concerned about this? Thanks Ron M. |
Author: | Alexandru Marian [ Fri Jul 25, 2008 2:31 pm ] |
Post subject: | Re: Claro Walnut Dust Contaminating Spruce Top |
You can do it as it will also protect it from general soiling, and from the glue of the bindings, and the tape of the bindings and so on. And to avoid dust issues, avoid the sandpaper and use a sharp scraper as much as possible. |
Author: | Michael Dale Payne [ Fri Jul 25, 2008 2:32 pm ] |
Post subject: | Re: Claro Walnut Dust Contaminating Spruce Top? |
It never hurts |
Author: | Ron M. [ Fri Jul 25, 2008 2:42 pm ] |
Thanks Alex and Michael. The top is a little dirty, will sanding remove it? I will apply some shellac ASAP. Thanks again for your help. Ron M. |
Author: | Michael Dale Payne [ Fri Jul 25, 2008 2:53 pm ] |
Ron wrote: Thanks Alex and Michael. The top is a little dirty will sanding remove it? I will apply some shellac ASAP. Thanks again for your help. Ron M. Sanding can actually work the contaminate oil and dust into the fiber. I would lightly scrape with a good sharp cabinet scraper |
Author: | Ron M. [ Fri Jul 25, 2008 2:54 pm ] |
Thanks Michael. Ron M. |
Author: | Hesh [ Fri Jul 25, 2008 3:44 pm ] |
Ron buddy if you are by chance going to use that dre*dful CA stuff.... ![]() In my experience when I do my final sanding with 220/240 and my Festool ES-125 ROS hooked up to a Festool CT-22 dust extractor any and all side wood dust and oil contamination is removed and the top is perfectly clean and dust free. |
Author: | Ron M. [ Fri Jul 25, 2008 7:50 pm ] |
Hesh wrote: Ron buddy if you are by chance going to use that dre*dful CA stuff.... ![]() In my experience when I do my final sanding with 220/240 and my Festool ES-125 ROS hooked up to a Festool CT-22 dust extractor any and all side wood dust and oil contamination is removed and the top is perfectly clean and dust free. Thats good to know Hesh, thanks a bunch. Can someone tell me how many coats of shellac is sufficent and the cut amount? Thanks. Regards, Ron M[ |
Author: | Ron M. [ Sat Jul 26, 2008 9:19 am ] |
Thanks Filippo. Ron M. |
Author: | Mike Collins [ Sat Jul 26, 2008 7:24 pm ] |
Ron -I hope you're doing your final sanding on the top last-after the rest of the guitar! That's the best way to make sure that any dust -etc. will be taken care of and there is no chance for more contamination! Whew! Sounds serious ! ![]() Mike ![]() |
Author: | Ron M. [ Sat Jul 26, 2008 8:58 pm ] |
Hi Mike, Actually, i haven't really begun sanding the entire guitar yet. The contamination results from sanding the top and back flush to the sides (didn't trust using my router), however, the top has gotten pretty dirty. Thanks for the tip. Ron M. |
Author: | Mike Collins [ Sun Jul 27, 2008 6:04 am ] |
Flippo is right. Just a lite coat will do. 2 lb. cut will suffice. Usually dust does not invade the wood to deepl . Unless it's a large particle that gets inbedded . Leave your tops a few thousands thicker than you want so you can sand this dust off as the last thing before finishing. Mike |
Author: | Ron M. [ Sun Jul 27, 2008 9:22 am ] |
Thanks M Mike Collins wrote: Flippo is right. That's good to hear Mike. I mixed a small batch of a 2lb cut of blond shellac last night that I will apply soon. Thanks for all your help, and thanks to everyone.Just a lite coat will do. 2 lb. cut will suffice. Usually dust does not invade the wood to deepl . Unless it's a large particle that gets inbedded . Leave your tops a few thousands thicker than you want so you can sand this dust off as the last thing before finishing. Mike Ron M. |
