It is currently Fri Jul 18, 2025 1:03 am
 Post subject: weight of CF vs wood
PostPosted: Sat Aug 16, 2008 9:32 pm
First name: Zachary
Last Name: Bulacan
City: Anchorage
State: Alaska
hi Guys
I don't have any carbon fiber but am planning the feasibility of using it in necks and was wondering how much it weighed compared to the same size of standard neck materials ( ie mahogany spanish cedar ect)
Zac
Anchorage Alaska
Finshed my 1st! See #1 here
 Post subject: Re: weight of CF vs wood
PostPosted: Sat Aug 16, 2008 10:18 pm
Last Name: Garrish
About 1.5x the density of ebony, about 2.5x the density of mahogany
Bob Garrish
PostPosted: Sat Aug 16, 2008 10:36 pm
First name: Zachary
Last Name: Bulacan
City: Anchorage
State: Alaska
Thanks ouch sounds like heavier then I want for a light uke neck...maybe stick to wood only
Zac
Anchorage Alaska
PostPosted: Sun Aug 17, 2008 11:44 am
Last Name: O'Melia
City: Huntsville
State: Alabama
CF in a Uke? Is that not like building a stick built home using all steel beams?
And, if you think you have tool issues now... ;)
PostPosted: Sun Aug 17, 2008 4:14 pm
First name: Zachary
Last Name: Bulacan
City: Anchorage
State: Alaska
laughing6-hehe ok maybe that was a bit of overkill for a soprano but i figured if the density was close it was just a bit more insurance to nice stable neck whats the difference in weight between spanish cedar and mahogany? is there a place to look at the various densities of common instrument woods?
Zac
Anchorage Alaska
PostPosted: Sun Aug 17, 2008 6:28 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
http://www.exotichardwoods-southamerica.com/index.htm
PostPosted: Sun Aug 17, 2008 7:54 pm
First name: Trevor
Last Name: Lewis
City: Crownsville
Zip/Postal Code: 21032
so how does the stuff cut??
http://www.PeakeGuitars.com
PostPosted: Sun Aug 17, 2008 10:37 pm
Last Name: Garrish
You need to cut it with a hacksaw or abrasive wheel because it's gross and likes to eat every kind of cutter, and it's pretty gross. I'd liken it to cutting the stuff abrasive wheels are made of, it's all black and dusty and icky. It's that way with most of the stronger composites.
Bob Garrish
PostPosted: Sun Aug 17, 2008 11:01 pm
http://www.fpl.fs.fed.us/documnts/fplgt ... 3/ch04.pdf
PostPosted: Sun Aug 17, 2008 11:25 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
That looks like a cool document...but try as I may, all my searches yielded no index of refraction!
Mike idunno
PostPosted: Mon Aug 18, 2008 6:09 am
Mike idunno
What is an index of refaction for wood? I know what an index is and I know that light refracts..but...?
PostPosted: Mon Aug 18, 2008 7:24 am
Last Name: O'Melia
City: Huntsville
State: Alabama
I know I should not do this... viewtopic.php?f=10101&t=16893&st=0&sk=t&sd=a&hilit=index+of+refraction&start=25 ;)
PostPosted: Mon Aug 18, 2008 8:56 am
I was curious about this a few weeks ago and did the experiment. I have a 1/4 x 3/8 x 3" piece of mahogany and a piece of carbon fiber rod with the same dimensions. I also have a gram scale that is accurate to .1 grams. Because I never get around to putting things away, they are still sitting on my desk. I'd expect the carbon fiber to be consistent in density but the mahogany sample I have feels like it is light. I've notice some pretty wide variation in mahogany's density.
Carbon fiber: 6.9g
mahogany: 2.6g
ratio: 2.7
PostPosted: Mon Aug 18, 2008 4:50 pm
First name: Zachary
Last Name: Bulacan
City: Anchorage
State: Alaska
WOW that is a pretty big difference I think I will stick to wood for the little ones wow7-eyes
is it really worth the trouble or is denser wood better at least safety wise? Hmm since I will only be building ukes or classical I think wood would be the better way to go. (low impact building for me ie less chemicals and things that are bad)
Zac
Anchorage Alaska
Users browsing this forum: DennisK and 15 guests
