Filling after finishing http://w-ww.luthiersforum.com/forum/viewtopic.php?f=10101&t=18882 |
Author: | James W B [ Sun Sep 21, 2008 7:02 pm ] |
Post subject: | Filling after finishing |
After shooting several coats of Nitro,I noticed a couple of very small holes in the Rosette, probably a couple of stray pores.I`m not sure I could even get a decent picture they are so small.Is it possible to fill these with CA,and if so should I wait until the Nitro cures? Or maybe I should try and drop fill with Nitro now and let it cure before rubbing out? Suggestions please. James W B |
Author: | James W B [ Sun Sep 21, 2008 8:54 pm ] |
Post subject: | Re: Filling after finishing |
Thanks Todd, James |
Author: | Robbie O'Brien [ Sun Sep 21, 2008 11:18 pm ] |
What Todd said. For some reason CA tends to be visible under a nitro finish but works well as a filler for cat urethane. |
Author: | TonyKarol [ Mon Sep 22, 2008 10:54 am ] |
My reason ... CA is too hard to use as a drop fill, its like a rock, then the nitro around it shrinks leaving witness lines, no matter how flat you have it sanded. its fine as a fill under the finish, or if you need to quickly fill something on the first coat, and then sand it back. |
