It is currently Tue Jul 15, 2025 1:36 am
 Post subject: Labels
PostPosted: Fri Sep 19, 2008 7:55 pm
Hi,
I would like to know were you all get those labels that goes down in the soundhole? You know the ones that says "hand crafted by" or etc... Is there a web-site were you can make your own from templates or something like that?
Jeff
 Post subject: Re: Labels
PostPosted: Fri Sep 19, 2008 8:53 pm
First name: Greg
Last Name: Harrington
I print sheets with MS Publisher, Cut, write serial#, Spray with flat clear lacquer and glue to the back prior to gluing the back to the ribs
Greg
PostPosted: Sat Sep 20, 2008 12:28 am
I think simple is good....
This one was done with Microsoft Word, printed several up per sheet of buff coloured paper. I just cut one off the sheet when I need one, and glue it down with whatever glue I am using for the instrument.
Some ukuleles...
Oh yes... and I have a "pet hate".... labels that state "Custom Made" on all instruments that people make. A custom really is only applicable when it is made to order for a specific individual, and then the label may say "Custom made for.... "
Rod
PostPosted: Sat Sep 20, 2008 6:08 am
Last Name: Collins
City: Argyle
State: New York
Zip/Postal Code: 12809
I buy parchment paper for mine.
it feels a bit like money paper.
I use Microsoft word also.
I print them with my H.P. Photo Smart printer.
I like the idea of coating them with finish first Greg!! [:Y:]
Mike Collins
PostPosted: Sat Sep 20, 2008 6:26 am
Last Name: Collins
City: Argyle
State: New York
Here's a better pix!
Mike Collins
PostPosted: Sat Sep 20, 2008 7:04 am
Some inkjet printers use water soluble ink. That can run from the glue, sweat, or a dripping guitar humidifier. Test yours first. One way around this is to make up your sheet of lables and coler xerox it at Kinkos.
PostPosted: Sat Sep 20, 2008 7:36 am
First name: Jeff
Last Name: Hewitt
Zip/Postal Code: 37312
Thanks for all the help....
Jeff
PostPosted: Sat Sep 20, 2008 8:12 am
I had a local print shop make mine . I use parchment paper also.
PostPosted: Sat Sep 20, 2008 12:39 pm
I just use a crayon.
PostPosted: Sat Sep 20, 2008 5:09 pm
I had the pleasure of playing around on my unkle's paul fisher rubio whilst i was in worcester last weekend.
i noticed that that guitar had rubio's name burned on to the back brace.
i would to find the machine that does that.
is it just done with a soldering of is there a special machine for branding nice neet letters in the spruce,
It looked way to need to be done by hand,but then so did the guitar :roll:
Joel.
PostPosted: Sun Sep 21, 2008 9:58 am
First name: James
Last Name: Bolan
City: Nashville
State: Tennessee
You can get soldering irons from Rockler woodworking.
James
James W Bolan
Nashville Tennessee
PostPosted: Sun Sep 21, 2008 11:35 am
First name: Patrick
Last Name: Hanna
State: Missouri
I'm a professional graphic designer, so you'd think I would have a pretty nifty logo and label, but I don't...yet. When I got ready to close the box on my archtop, I considered a label but didn't want to take the time to design it. I do this sort of work day in and day out for other people, but have a hard time being objective about designs for myself. In the end, I just signed and numbered the guitar across the face of both end blocks with a sharpie. Before I finish another instrument, though, I'll have a label. And, as several have suggested, this is an easy thing to print on your computer printer, or at the local copy store. Like anything else regarding the building process, experiment on scrap labels first, and make sure they won't run or smudge while you are gluing them in.
PostPosted: Sun Sep 21, 2008 12:54 pm
Here is a tip for those who can use it:
I attach the label after the back is final sanded and then cover the label with a piece of clear plastic from a Baggie. I use 14 day "Blue" tape which comes off easily once the guitar is completely finished and prior to stringing her up. It is MUCH easier to attach the label and get it nice and straight before the back is attached to the rim.
My labels are made using a multi-step process that begins with taking a high-res picture of the actual back wood/plate. This picture, using Photoshop, becomes the background for my label and is unique to every guitar that I build.
The label's logo, serial number, and date are superimposed on the background picture of the actual back wood and printed with an Epson ink jet using 100 year photographic ink.
The next time I do this I am going to try some rattle can nitro, just a misting with the hope that it won't interact poorly with the ink.
My labels are attached with 3M spray adhesive and I go to some pains to feather my back joint reinforcement so that the label makes a smooth transition up over the BJR and down the other side.
PostPosted: Sun Sep 21, 2008 9:59 pm
Joel.
Joel, you can get branding irons from a business called Brand New.
http://www.brandnew.net
I have gotten several irons from them over the years to mark my furniture. Since my pieces are all custom, I use the irons that you just heat up with a propane torch. Brand the wood, sand it up a little and bam, cool custom brand in your wood.
chris
Chris Oliver
Infinity Luthiers
...in the shop.
live every minute...
PostPosted: Mon Sep 22, 2008 12:53 pm
Joel, I have in the past designed Lance’s and John How’s labels for them as well some others not members here and my own of course. Once the design is approved I provide a 6 to the page file you can print on any color printer. Depending on what you want the typical charge is $50 for OLF members. I am not really seeing more work right now but if you want a custom design PM I will try to squeeze you in.
PostPosted: Mon Sep 22, 2008 2:19 pm
I make my labels very differently than the rest of the pack. I use hardwood veneers and brand them. Sometimes I stain them sometimes not. I usually do a quick french polish to them.
A totally different look
The examples below are rejects where my branding iron was not quite right
PostPosted: Mon Sep 22, 2008 2:34 pm
I like that Andy [clap] [clap]
PostPosted: Mon Sep 22, 2008 4:13 pm
I like something a little more permanent.
Woodburner.
PostPosted: Thu Sep 25, 2008 4:44 am
What colour?
PostPosted: Thu Sep 25, 2008 5:41 am
This is about the most elaborate label making process I have seen. Jamie Wiens makes replicas of vintage Loar signed mandolins, and the attention to detail both in authentic materials and traditional methods is astounding. This goes for the process of making the famous oval shaped labels as well, check it out:
http://www.wiensmandolins.com/
PostPosted: Thu Sep 25, 2008 8:17 am
Or use a spray watercolor or ink fixative I use 3m 7819 I believe is the number but could be wrong I have not had to ordered any in while Krylon also makes a good one and one or the other are available at a good art supply retailer.
