It is currently Fri Jul 25, 2025 12:20 pm
PostPosted: Fri Aug 01, 2008 7:44 pm
Some of you asked to see photos of this guitar when it was finished. I just shipped it today. I'm quite happy with it.
I've done nothing to increase color saturation. This is some of the special cocobolo that Allied had a little while back. The rosette is camphor burl.
PostPosted: Fri Aug 01, 2008 7:54 pm
Wow....every bit as gorgeous as I was expecting. Very nicely done Howard...as usual.
PostPosted: Fri Aug 01, 2008 8:21 pm
First name: Gene
Last Name: Zierdt
City: Sebastopol
Zip/Postal Code: 95472
Howard,
A Gorgeous guitar, you can be proud bliss bliss
I love the color combinations... [:Y:]
Gene
PostPosted: Fri Aug 01, 2008 8:54 pm
First name: Zachary
Last Name: Bulacan
City: Anchorage
State: Alaska
WOW! [clap] that blows me away very nice work and the wood too! :D I like the neck design and wood rosette
Zac
Anchorage Alaska
Finshed my 1st! See #1 here
PostPosted: Fri Aug 01, 2008 9:16 pm
Rather minimalist for a Klepper! :D
Spectacular and flawless as we've come to expect. Beautiful Howard...thanks for posting.
PostPosted: Fri Aug 01, 2008 9:48 pm
Oomph! Thats a guitar I would reach for. Dig the rosette, and that wood just grabs you.
Gabriel Regalbuto
Carlsbad, California
Freedom 35!
PostPosted: Fri Aug 01, 2008 11:05 pm
As beautiful as was expected, Howard.
I love the color palette of this instrument.
And, there's a nice 3-piece back for you, JJ!
PostPosted: Sat Aug 02, 2008 5:25 am
Howard,
Thats as gorgeous and impeccably elegant as all of your creations - lovely wood combinations and craftsmanship as always. What wood is the top?
Playing a combination of African Blackwood/Cocobolo in a small room will be like playing in your own private Cathedral - I bet you could get lost in there forever!
Hats off to you (we need one of those emoticons but this one will do) [clap] [clap] [clap] [clap] [clap]
PostPosted: Sat Aug 02, 2008 6:03 am
Location: Between Bordeaux and the Atlantic. S.W.France
To reiterate what Dave said from my neck of the woods, 'Chapeau Howard'.
PostPosted: Sat Aug 02, 2008 6:04 am
Wow this is a killer guitar Howard! [:Y:] [clap] [clap] [clap] [clap] [clap] [clap]
PostPosted: Sat Aug 02, 2008 9:18 am
Great work, Howard. That cocobolo is spectacular. A lovely top too.
Ken Franklin
clumsy yet persistent
PostPosted: Sat Aug 02, 2008 9:23 am
A stunning guitar!
Love the attention to detail; the rope/style purfling around the rosette is exquisite
PostPosted: Sat Aug 02, 2008 9:50 am
Man, do I like that!!!
As others have said, the colours are just beautiful!
Howard, could you expand on the whats & hows of the soundport binding?....I'd like to try something similar. Thanks
Milton, ON
PostPosted: Sat Aug 02, 2008 9:55 am
MMMMMM MM MMMM MMMM MMMMMMM! What a beauty. [clap] [clap] [clap] [clap] [clap]
PostPosted: Sat Aug 02, 2008 11:19 am
Bravo! Very dramatic wood choices.
PostPosted: Sat Aug 02, 2008 11:27 am
City: Battle Ground
Howard, the artist in you always comes through in every detail. Beautiful.
PostPosted: Sat Aug 02, 2008 3:44 pm
What does this thing sound like? It must be amazing!!
PostPosted: Sat Aug 02, 2008 5:33 pm
Amazing workmanship, just amazing something to aspire to!
Formerly JJH
PostPosted: Sat Aug 02, 2008 5:56 pm
I guess that's pretty cool. If you're into guitars with amazing craftsmanship and incredible artistic design, anyway.
That is beautiful, Howard.
PostPosted: Sat Aug 02, 2008 6:13 pm
Howard
It looks “to good to sell” .
Is it a OM size with 12 fret to body?
What are you doing in/around the sound hole?.
Great work.
yours Geordie
some tunes on acoustic and guitar synth.
http://www.youtube.com/user/TheGeordieAdams
http://www.myspace.com/geordieadams
PostPosted: Sat Aug 02, 2008 6:41 pm
That's really nice Howard!
Bet it sounds great!
PostPosted: Sat Aug 02, 2008 7:11 pm
Well, thanks to all!
This was a commission, and I got it because the buyer has a friend who has a Klepper and he loves it and the buyer wanted one similar.. That's the way it's supposed to work, no? It's very similar to the friend's guitar, except the latter has an all African blackwood back. Yes, 12 fret OOO size; my own plantilla. The top is Swiss alpine spruce, bridge and fretboard African blackwood. Brazilian satinwood in the neck centerstripe and one of the headstock layers, as well as the soundport binding.
Re soundport: I bore the hole after bending (and, in most cases, laminating) with a sawtooth type Forstner bit. I've found it goes better to bore from the inside, which may be counterintuitive since usually there is more splitting on exit. In this case, the curve of the sides makes inside-out the direction that cuts downhill to the grain, and that matters more. I match the side purfling with black and white fiber "fishpaper" cut from sheets (so it will be deep enough to allow for the side curvature). Then I glue in a turned ring to match the binding, and trim it flush to the top and round the edge down like I do with the binding. I once was successful using a drill press to cut out a ring using a dowel cutting bit and Forstner bit, but the lathe lets me get the size just right, with a very slight taper for a tight fit. It's a simple bit of turning, done freehand on a small wood lathe. When I get close to size. I test it on the guitar body before parting it off on the lathe. This photo of the friends guitar shows the style of the port binding and purfling a bit better:
PostPosted: Sun Aug 03, 2008 8:33 am
Thanks for the insight re the soundport Howard........it's very elegant!
Milton, ON
PostPosted: Sun Aug 03, 2008 8:36 am
Howard...any chance you could do a tutorial on how you get the backstrapping effect on your neck volute? That just reeks class and craftsmanship!
TIA
PostPosted: Sun Aug 03, 2008 9:02 am
Thanks for posting the sound port pic. It just looks very elegant.
So much better than just a hole cut in the side like mine.I have got to
dress up my ports.Thanks for the inspiration Howard.
Very lovely guitar btw. :D [:Y:]
