Setting the M&T Neck bolts (tutorial) http://w-ww.luthiersforum.com/forum/viewtopic.php?f=10101&t=18989 |
Page 1 of 2 |
Author: | LanceK [ Tue Sep 30, 2008 8:35 am ] |
Post subject: | Setting the M&T Neck bolts (tutorial) |
I use to pre drill my bolt holes in the neck blocks but I always found it difficult to both make sure the block was dead on center and also that the holes lined up perfectly with the inserts in the tenon on the neck, Both vertically and horizontally. I decided id try to do everything after the box was closed up. That meant installing the neck block with no mortise or bolt holes and after the box was together cutting the mortise and drilling the holes for the bolts as well as counter sinking there heads. I cant recall who (maybe it was Larry Presenall) that turned me on to a reverse spotfacer bit. That turned out to be just the ticket for countersinking the heads of the bolts inside the box. Anyways for anyone interested, this is a quick tutorial on how I set the bolts. The first thing I do is cut the mortise, I don't have any picture of this process but its nothing unusual. Chuck the body in the jig and cut the mortise. Then I screw in a bolt that I ground to a point in to the top insert in the neck. Attachment: S1052568.JPG Attachment: S1052567.JPG Next I take the neck and "PRESS" it in place marking the spot where I will eventual drill. Attachment: S1052569.JPG Attachment: S1052570.JPG For reference here is what the reverse spotface bit looks like. Attachment: S1052571.JPG Once the arbor is through the hole you attach the cutting head from inside the box. Attachment: S1052572.JPG The next step is to drill the holes for the reverse spotfacer arbor to got through, Attachment: S1052575.JPG Attachment: S1052577.JPG Then replace the drill bit with the arbor and push it through in to the guitar box. Attachment: S1052579.JPG Once the arbor is inside you reach in the sound hole and attach the cutter. Attachment: S1052580.JPG Pulling up on the drill the cutter makes the proper sized counter sunk holes for my bolts. Attachment: S1052597.JPG Here are a few more shots of the process completed. Hope this helps someone! ![]() Attachment: S1052602.JPG Attachment: S1052609.JPG Attachment: S1052610.JPG Attachment: S1052578.JPG
Author: | Dave Anderson [ Tue Sep 30, 2008 9:32 am ] |
Post subject: | Re: Setting the M&T Neck bolts (tutorial) |
Thanks for the tutorial Lance. I want to get a spot-face bit myself. Where did you get it ?? Are you bolting the fb. too or gluing it down? I'm bolting mine for the first time on my current geetar. It's extra work but I think it will be worth it. Cool tip ,sharpening the bolts like that! |
Author: | Hesh [ Tue Sep 30, 2008 9:34 am ] |
Very nicely done Lance my friend! ![]() ![]() ![]() ![]() ![]() ![]() Where do you get those bolts please? |
Author: | GCote [ Tue Sep 30, 2008 9:44 am ] |
That spot facing bit looks like one that you can get at woodcraft in with the pen making supplies. It is used for trimming the barrels on the pen planks. Gary |
Author: | L. Presnall [ Tue Sep 30, 2008 9:46 am ] |
The spot facer can be had from Aircraft Supply...that's pretty close at least...Google will give up the proper info! Nice tutorial Lance! ![]() |
Author: | LanceK [ Tue Sep 30, 2008 9:55 am ] |
Thanks Guys, Dave no im still gluing down the extension. Hesh the bolts come from Lowes ![]() The spotfacer came from http://www.panamericantool.com |
Author: | SniderMike [ Tue Sep 30, 2008 10:02 am ] |
Lance, I like it! Thanks for sharing. |
Author: | Terence Kennedy [ Tue Sep 30, 2008 11:00 am ] |
Nice job. You can get them at theyardstore.com too. They also work well for putting a pickup jack in a guitar that has a thick end block (like some of Charlie Hoffman's early ones) where you have to countersink the inside of the end block. Terry |
Author: | Pat Foster [ Tue Sep 30, 2008 11:17 am ] |
Thanks, Lance. ![]() Is it a 1/4" dia. arbor? Pat |
Author: | LanceK [ Tue Sep 30, 2008 11:20 am ] |
Pat, I was trying to remember what size it was this morning when I was writing this tut up.. Ill check when I get home... |
Author: | Brock Poling [ Tue Sep 30, 2008 12:13 pm ] |
Hesh wrote: Where do you get those bolts please? When you are asking for them in the hardware store they are called furniture bolts. |
Author: | Howard Klepper [ Tue Sep 30, 2008 12:13 pm ] |
I do some the way Lance does; other by drilling the head block before closing the guitar and then marking the tenon with a pencil stuck through the block after the box is closed. But I'd recommend not drilling the block without a waste block clamped to the inside to prevent splitting when the drill bit exits. Even a good lip and spur bit can leave an exit wound. You can clamp the right size block using the soundhole--a clamp on either side will allow room for drilling. MSC also has reverse spotfacers. And I drill the block 5/16" for a 1/4" bolt. Gives you a bit of slack without weakening things. |
Author: | Joe Sustaire [ Tue Sep 30, 2008 12:28 pm ] |
Thanks Lance, that is a very helpful tutorial. That reverse spot face bit is the ticket. Dave Anderson mentioned bolting down the fretboard overhang instead of gluing. How do you do that? Thanks, Joe |
Author: | LanceK [ Tue Sep 30, 2008 12:33 pm ] |
Howard Klepper wrote: But I'd recommend not drilling the block without a waste block clamped to the inside to prevent splitting when the drill bit exits. Even a good lip and spur bit can leave an exit wound. Howard, this is good advise! Ill do this next time. Although I have never had a problem, this is good insurance! Thanks! ![]() |
Author: | Billy T [ Tue Sep 30, 2008 1:24 pm ] |
They also make countersinks! I've used those for years, some jobs can't be done without them! Very handy! Thanks Lance for showing your process! |
Author: | BruceH [ Tue Sep 30, 2008 5:23 pm ] |
I visited a fellow guitarbuilder last week and he showed me his homemade spotfacing bit. He used a spade bit and ground cutting edges on the upper edge. Cheap and effective. |
Author: | Terry Stowell [ Tue Sep 30, 2008 6:45 pm ] |
Post subject: | Depth Stop? |
What, no depth stop!?! ![]() |
Author: | joe white [ Tue Sep 30, 2008 7:00 pm ] |
Great tutorial Lance. ![]() |
Author: | Dave Anderson [ Tue Sep 30, 2008 7:21 pm ] |
sustaireblues wrote: Thanks Lance, that is a very helpful tutorial. That reverse spot face bit is the ticket. Dave Anderson mentioned bolting down the fretboard overhang instead of gluing. How do you do that? Thanks, Joe Hey Joe! I routed out a mortise on the top of the guitar and glue on the tenon on the underside of the fingerboard. I drill two holes and used t-bolts and bolted the extension down. Also a 1/2" piece is glued on the top side of the neck block before the top is glued on to have something to rout into. |
Author: | LanceK [ Tue Sep 30, 2008 7:41 pm ] |
joe white wrote: Great tutorial Lance. ![]() Just took it to the grinder.... |
Author: | Dean [ Tue Sep 30, 2008 9:00 pm ] |
If you don't have a lathe, put your stud in an electric drill and turn it on as you go at it on the grinder. Nice tutorial. |
Author: | Parames B [ Tue Sep 30, 2008 9:36 pm ] |
Post subject: | Re: Depth Stop? |
Nice tutorial, thanks. I am wondering the same with Terry above . How's the depth of cut controlled? Thanks. |
Author: | Jim Watts [ Tue Sep 30, 2008 11:11 pm ] |
Lance, Nice job ![]() |
Author: | LanceK [ Wed Oct 01, 2008 7:35 am ] |
ParamesB wrote: Nice tutorial, thanks. I am wondering the same with Terry above . How's the depth of cut controlled? Thanks. The depth of cut is done by feel, drill a little, pop it out and feel, test fit the bolt, repeat. It doesn't cut SUPER fast, and your cutting on the pull not the push, so that also makes it hard to over do it. I just use my electric hand drill, hit it for maybe 2 or 3 seconds and check. |
Author: | Kirt Myers [ Wed Oct 01, 2008 9:01 am ] |
You could probably mark the shank with a sharpie or a piece of tape at the outer surface of the headblock. That looks nice and clean with the heads counterbored. Thanks for the tute. |
