Laminated Neck
http://w-ww.luthiersforum.com/forum/viewtopic.php?f=10101&t=19462
Author:  DannyV [ Sun Nov 02, 2008 9:28 am ]
Post subject:  Laminated Neck
Just getting a start on #2. A 12 fretter with slotted headstock, in the new shop and loving it I might add. I'm doing a laminated neck. Would one be inclined to do a scarf for the headstock angle or just cut it out on a bandsaw? I guess theoretically you would have more strength from a scarf. Saving wood's not really an issue. It will be out of local Big Leaf Maple which there's no shortage of. What do most of you do?
Cheers,
Danny
Author:  TonyKarol [ Sun Nov 02, 2008 9:31 am ]
Post subject:  Re: Laminated Neck
If it were a laminated neck with contrasting woods, I would cut the headstock out, as if the scarf joint is not dead on, you wil see wierd mismatch lines most likley in the string ramps.
I only scarf for a slot head if trying to make the neck look like its truley one piece, and add a back plate to cover the joint line.
When wood is plentiful, just do it the easier way - cut it out of one piece.
Author:  Mark Groza [ Sun Nov 02, 2008 5:24 pm ]
I personally don't like scarf joints.I usually laminate for strength so i don't have to.I don't even scarf on one piece necks.I think they make a guitar look cheap.It looks to me like the board wasn't long or thick enough,so another piece was just glued on.You almost always see it on cheap guitars.
Author:  Barry Daniels [ Mon Nov 03, 2008 11:22 am ]
I have made several laminated necks with scarf joints on the major pieces (not the thinner laminations). In order to prevent misalingment of the laminations, I scarfed the pieces first, then laminated everything. Overkill? I don't think so. The benefits of scarfing are still there.
