It is currently Mon Jul 28, 2025 3:27 pm
PostPosted: Tue Nov 04, 2008 2:45 pm
First name: Chuck
Last Name: Hutchison
City: Houston
Can I pick you brains on which way to cut this mahogany block to make the inside heel block? I'll also need to have enough to make the neck heel too.
Here's a couple pictures of what I have.
Muchas gracias
PostPosted: Tue Nov 04, 2008 3:26 pm
Ideally you want to have the end grain on the sides of the block -not glued to anything-, top and back plates glued to the flat sawn part and sides glued to the quartersawn part. I generally use slightly rift sawn stock for the blocks with the most quartersawn part glued to the sides.
Laurent Brondel
West Paris, Maine - USA
PostPosted: Tue Nov 04, 2008 4:22 pm
Oh, no! LMI is now calling the head block "heel block." If that's a heel block, what is the block you glue to the neck when you are laminating a heel to the neck? And then what is the block at the bottom of the guitar? Or isn't that the bottom? I guess not while you are playing.
Riddle: what is both head and heel, and is found in the middle?
PostPosted: Tue Nov 04, 2008 4:40 pm
First name: Chuck
City: Houston
Howard Klepper wrote:
Oh, no! Or isn't that the bottom? guess while you are playing.
The number eight?
PostPosted: Wed Nov 05, 2008 8:51 pm
First name: Chuck
City: Houston
Many thanks to you Laurent. That got me to see the block of wood and how to cut it. I really appreciate your help.
Users browsing this forum: ChuckB and 11 guests
