Unmatched Indian rosewood? http://w-ww.luthiersforum.com/forum/viewtopic.php?f=10101&t=19639 |
Author: | Alexandru Marian [ Wed Nov 12, 2008 10:24 pm ] |
Post subject: | Unmatched Indian rosewood? |
I recently started my number 3, and pulled the only rosewood set I can use right now for thinning, and it i snot looking too good. The sides are a strong purple, while the back is mostly brown, with only a small hint of purple, definitely not as much as the pic shows. But the sides are as purple as the pic...go figure... ![]() Under a wipe of shellac the difference reduces but still... I heard the purple tone disappears in time. Would you build with it? Or should I order a couple more sets and match them better. Unfortunately that would mean at least a couple months of setback... |
Author: | Jon L. Nixon [ Thu Nov 13, 2008 12:01 am ] |
Post subject: | Re: Unmatched Indian rosewood? |
Alexandru- I personally would use that set in a heartbeat. Under a glossy finish and with a little photoaging you will later wonder what the fuss was about ![]() |
Author: | WaddyThomson [ Thu Nov 13, 2008 10:31 am ] |
Alex, I would use the set too. Under finish, I don't think you are going to be able to see the difference in the woods, particularly since they will be at right angles to each other. Go for it! ![]() |
Author: | Bob Garrish [ Thu Nov 13, 2008 12:51 pm ] |
It all turns the same colour with age...which could be to your benefit. Leave the sides sit in the sun a bit (indoors), on the order of a few hours, and they'll fade toward brown. You can probably get a really close match. Or, as mentioned, you'll notice it's all the same colour in a couple years anyhow! I left a set of ten very differently coloured IRW fretboard blanks in my 'foyer' here, where they'd get some sun every day. After a couple days they were all identically brown. Face mill them, though, and the brown only went to a certain depth (ie: upon machining new, unfaded colour showed up). |
Author: | Bill Greene [ Thu Nov 13, 2008 2:25 pm ] |
Agreed. The most recent set I used was very similar with regards to the purple vs. brown issue, and by the time I got to the pore fill the colors were indistinguishable. I would think you're ok. And by the way, I like the purple stuff best. |
Author: | Alexandru Marian [ Thu Nov 13, 2008 2:30 pm ] |
Thanks, I'll go ahead and use it as is. |
Author: | Mike OMelia [ Thu Nov 13, 2008 3:37 pm ] |
No! Do not use it. Mail it to my home address. ![]() Mike |
Author: | WaddyThomson [ Thu Nov 13, 2008 3:47 pm ] |
Dang, why didn't I think of that! ![]() ![]() |
Author: | Mike Collins [ Thu Nov 13, 2008 3:58 pm ] |
Wow Alex ! These guys are right on the money ! Use it! With the wood supply & deforestation were lucky to get any nice woods from India -or anywhere that does not limit slash & burn or clear cutting! Guitar wood prices are going sky high!!!! -because the supply is low & the demand is high! Plus-what does color match have to do with the tone & sound of your guitar?? Mike ![]() |
Author: | Alexandru Marian [ Thu Nov 13, 2008 4:04 pm ] |
![]() And I actually like to use as much of the wood as possible. For example a neck blank if not undersized and if cut carefully easily yields two back braces, plus a bunch of individual lining blocks... |
Author: | WaddyThomson [ Thu Nov 13, 2008 4:12 pm ] |
Well, mailing it to one of us is not "throwing it out the window", is it? ![]() ![]() |
Author: | Alexandru Marian [ Thu Nov 13, 2008 4:13 pm ] |
I already shared the pics! ![]() |
Author: | wbergman [ Thu Nov 13, 2008 4:17 pm ] |
I once had a famous builder mention to me that the finish ties the sound together, and a tint in the finsih ties the color together. I don't know if he meant the kind of situation you describe. |
Author: | WaddyThomson [ Thu Nov 13, 2008 4:17 pm ] |
How did I already know that? ![]() |
Author: | Mike OMelia [ Thu Nov 13, 2008 6:24 pm ] |
Alexandru Marian wrote: I already shared the pics! ![]() Well gotta agree with ya there. I'm pretty picky about who gets to have some ... Oops. Family site. Mike |
Author: | Steve Kinnaird [ Thu Nov 13, 2008 10:24 pm ] |
Alexandru, I'd use it too. In fact, I must have had the sister set to that one, or the matching pieces to your mismatched pieces. Well, it/they turned out just fine. Another solution is to buy a set of maple, and build a dark/light guitar like Howard Klepper does. You'll have enough wood for two guitars, and then the match won't matter. They'll be staring at the rosewood against the maple, and vice versa. Steve |
