It is currently Tue Jul 29, 2025 11:43 pm
PostPosted: Sun Dec 07, 2008 1:44 pm
I bought a Caliber III to monitor the RH in my shop. It had good reviews and the price was right. I needed a clock so I grabbed a cheap wall clock with thermometer and hydrometer. I figured it would take a day or so for it to settle in. Well, after a week of 13-15 points difference, I decided that I needed a better analog hydrometer. So I found one that reports to use a hair. Within few hours the two analogs where within 3 points of each other, leaving the digital way below. After reading that some hydrometers are only accurate within a certain range, I decided to bring the shop's RH down to about 50% according to the analogs, hoping that the three would get closer. Nope, the digital was still way lower. Life got busy and I left the shop sitting at the analog's 50%. I watched as the top and back I had joined curl and then flatten after flipping them. It stopped after two days.
Enters JJ's post on making a sling psychrometer. The two thermometers arrived from 4physics.com yesterday. The analogs are basically correct. The sling psychrometer split the difference between the two.
For $13 and two pieces of tape, I have piece of mind and can start gluing.
Thank you JJ for taking the time to post.
PostPosted: Sun Dec 07, 2008 8:27 pm
Happy to know that it worked out for you Lillian. The only negative I found was that those thermometers are tough to read for me unless I'm wearing my magnifiers.
Peace of mind is always a good thing! [:Y:]
PostPosted: Sun Dec 07, 2008 8:36 pm
Yes it is. Thank you.
And its good to know it wasn't just my eyes. :lol:
