It is currently Tue Jul 29, 2025 11:39 pm
 Post subject: jatoba for neck?
PostPosted: Fri Dec 12, 2008 5:26 pm
Hi All,
I just bought a board of jatoba. I'm thinking of using this in a laminated neck with purple heart. Any thoughts on using this wood for a neck?
Also I just brought it home from the supplier. How long do you recommend it acclimatize to the shop?
Any help much appreciated,
Stefan
 Post subject: Re: jatoba for neck?
PostPosted: Fri Dec 12, 2008 6:03 pm
Hi Stephan
I'm thinkin it would make a pretty heavy neck.
Lots of variables how long you should sticker it for.
you should get yourself a moisture meter, when the wood gets to be 6 to 8 % it,s good to go.
PostPosted: Fri Dec 12, 2008 7:19 pm
I'm far from an expert but my understanding is the it is similar to cherry which is fine for necks.
PostPosted: Fri Dec 12, 2008 7:22 pm
First name: paul
Last Name: harrell
City: Pittsboro
I have built several guitars using Jatoba for the back and sides - very stable, works easily, but weight is a problem for necks, and it seems very heavy to me.
Paul
