Need install measurements for Gotoh 510s
http://w-ww.luthiersforum.com/forum/viewtopic.php?f=10101&t=20060
Author:  Ricardo [ Tue Dec 16, 2008 4:39 pm ]
Post subject:  Need install measurements for Gotoh 510s
Can someone tell me the set back from edge of peghead and hole size for Gotoh 510's? Thanks
Author:  Michael Dale Payne [ Tue Dec 16, 2008 4:48 pm ]
Post subject:  Re: Need install measurements for Gotoh 510s
as found on Stewmac's site
I set mine back .5625" 10mm brad point for the drill
Author:  Rod True [ Tue Dec 16, 2008 4:52 pm ]
I offset 1/2" from the edge. I use a 25/64" bit to drill for tuner holes.
Author:  Ricardo [ Tue Dec 16, 2008 4:56 pm ]
Thanks guys for the speedy replies! bliss
Author:  TonyKarol [ Tue Dec 16, 2008 4:56 pm ]
1/2 to 9/16ths offset .. 3/8 hole, then ream to fit.
Author:  Hesh [ Tue Dec 16, 2008 4:56 pm ]
Michael my friend is there any particular reason why you use .5625" as your set-back spec?
Author:  Rod True [ Tue Dec 16, 2008 5:22 pm ]
Because he's an engineer and thinks in decimal inches instead of fractions of an inch :D
I think the same way.
0.5625"=9/16"
