She is done
http://w-ww.luthiersforum.com/forum/viewtopic.php?f=10101&t=20314
Author:  Tai Fu [ Sat Jan 03, 2009 10:21 pm ]
Post subject:  She is done
I polished the finish and glued on the bridge. I used a router to route off the finish then cleaned it off with sandpaper and chisel and razor blade while taping up other areas to protect the finish. I did it kinda fast and the finish is still a little soft so I did leave some imprints in the finish with the tape but you'd have to be really close in the right light to see it. I also routed a ledge in the bridge itself to allow the bridge to sit a little higher over the finish resulting in a clean appearance. I drilled two holes beforehand so I can glue up the bridge without fear of the bridge moving while gluing (would be a real nightmare!)
Next I will install tuner and nut then string it up and hopefully it will sound good... This guitar is going to be delivered to Afghanistan by a missionary team... I hope the Taliban doesn't harass them for no reason.
Author:  ChuckH [ Sat Jan 03, 2009 10:23 pm ]
Post subject:  Re: She is done
Wow Tai,
It just seemed like yesterday your were showing pictures of it on your bed. You got it finished Fast.
Great job.
Author:  Hesh [ Sun Jan 04, 2009 7:44 am ]
Very nice Tai Fu - congratulations! [:Y:] [clap] [clap] [clap] [clap] [clap] [clap]
Author:  woodhands [ Sun Jan 04, 2009 10:58 am ]
Looks great! Hopefully it survives the trip.
