It is currently Fri Aug 01, 2025 10:36 am
 Post subject: top questions
PostPosted: Fri Jan 09, 2009 8:00 am
what is the best way to cut out the sound hole, using the router i used to cut the rosette channel with or the popsicle stick method, and what is your recommended way of attaching the top to the sides.
 Post subject: Re: top questions
PostPosted: Fri Jan 09, 2009 8:07 am
If you have a router jig to do a rosette , then you are set for cutting out the soundhole ...
As for gluing on tops and backs, I use my go bar deck ...
Users browsing this forum: Bing [Bot], Terence Kennedy and 37 guests
