Purfling cutter mod http://w-ww.luthiersforum.com/forum/viewtopic.php?f=10101&t=20687 |
Author: | jordan aceto [ Mon Jan 26, 2009 2:35 pm ] |
Post subject: | Purfling cutter mod |
A while ago i posted an easy way to turn a drill press circle cutter into something closely resembling the schnieder gramil sold by lmi. I modified it again to accept a radiused scraper for consistently scraping the edge fluting on violins. It could easily be adapted for scraping the recurve on archtop guitars and mandolins. Attachment: Picture 026.jpg I simply cut a slot with a thin hacksaw, allowing the cut to wander a little bit for a gentle curve. Then i jammed a cut down scraper blade into the curved slot, which eliminates the need for a set screw. Attachment: Picture 029.jpg It is quite comfortable to pull around the perimiter, and it makes a time consuming job a little bit more brainless(which is good for people like me). |
Author: | efialtis [ Tue Jan 27, 2009 12:24 am ] |
Post subject: | Re: Purfling cutter mod |
Thanks' Jordan, I just purchased a general 55 circle cutter after seeing your last post and was thinking of making a small brass holder to insert into the existing cutter slot and hold a small scaper in this manner.Regards,Chris. |
