It is currently Sat Aug 02, 2025 10:13 am
 Post subject: 12 string bracing
PostPosted: Tue Jan 27, 2009 7:07 pm
Hi all,
wondering if anyone can point me in the right direction here. I would really like to start building a 12 string acoustic but I am a little unsure of the sound board bracing, is it the same as a 6 string? Does it need to be beefed up a bit because of the added string pressure? Also is the top thickness increased at all?
Paul
 Post subject: Re: 12 string bracing
PostPosted: Tue Jan 27, 2009 7:21 pm
Paul, here's a good place to start:
http://www.luthiersforum.com/forum/viewtopic.php?f=10101&t=19759&p=277392&hilit=+12+string+nut#p27read%207392
Informative 12 string thread, helpful pictures. KiwiCraig's 12-banger is a real beaut.
Jim Womack
Will Rogers
PostPosted: Tue Jan 27, 2009 8:11 pm
Thank You, that is exactly what I was looking for
Regards,
Paul
PostPosted: Tue Jan 27, 2009 9:08 pm
Paul...I am about a week or 2 away from stringing up a slope shoulder dred 12er. And while I can't state that my bracing scheme is going to be successful yet, here's what I did differently from a 6er.
1) Increased the x-brace height at the intersection from .500" to .625"
2) Increased the bridgeplate width ftom 1.5" to 1.75"
It's still quite light and hopefully will be lively. Time will tell. Check out this build thread http://www.luthiercom.org/phpBB3/viewtopic.php?f=93&t=359
Have fun!
PostPosted: Tue Jan 27, 2009 11:19 pm
Here is my 12 string bracing.
Many feel it is my best guitar
PostPosted: Wed Jan 28, 2009 5:26 pm
My last 12 was a Small Jumbo in Spruce/EIR. I made the top about 25% thicker than usual, and used my standard double-X bracing, but 25% taller than normal, and a little wider to preserve the gluing area. since stiffness goes as the cube of top thickness/brace height, that made the whole thing twice as stiff for a little more than a 25% increase in weight. It's a cannon: I've got a reasonably strong voice, but I couldn't sing over this guitar, and it's only got a 24.5" scale length.
