Hollow Screw Extractor
http://w-ww.luthiersforum.com/forum/viewtopic.php?f=10101&t=21033
Author:  Chris Paulick [ Sat Feb 14, 2009 2:14 pm ]
Post subject:  Hollow Screw Extractor
Anyone have one of these in 3/8" and 5/16" who can tell me what the ID is. I'm wanting to see if I can use them to cut fret board dots from shell.
http://www.woodcraft.com/family.aspx?FamilyID=983
Author:  WaddyThomson [ Sat Feb 14, 2009 2:58 pm ]
Post subject:  Re: Hollow Screw Extractor
I posted this at MIMF too, but doesn't the screw extractor grip/cut in the reverse direction? You would have to cut using a reversible drill. Not a major issue, but most are slow for cutting.
Author:  Chris Paulick [ Sat Feb 14, 2009 3:14 pm ]
Not a problem. I'm interested in the ID. It's either one of these or I'll make template and use a collar and mill with a PC310 router.
Author:  Steve Marcq [ Sat Feb 14, 2009 6:08 pm ]
I read somewhere about how to cut shell a bit oversize, then CA it onto the end of the same drill bit you'll use to drill the hole. Reverse the bit in a drill, and hold a sanding block against the spinning shell to get it to exactly the drill diameter.
Haven't tried it, but I would if I wanted an odd size dot, or of a type of shell unavailable precut.
Author:  Mark Groza [ Sat Feb 14, 2009 8:39 pm ]
I do it like steve said.Except you should also grind the drill bit flat on the bottom so the shell has a larger area to glue it to.Works great!
Author:  Stephen Boone [ Sun Feb 15, 2009 12:17 am ]
I have them and have never used them. I will try to find them tomorrow 2-15 and report then. (I think I know where they are.????)
Author:  Stephen Boone [ Sun Feb 15, 2009 12:31 am ]
Well, I knew I would never get to sleep wondering where those things got to so I went downstairs and found them....
O.D. .370-I.D .311
O.D. .292-I.D. .240
O.D. .310-I.D. .250
I have three sizes unlabeled so those are the actual measurements for the three. The cutters are a bit rough so I would expect some chatter. I also had to measure several times and take a rough average. I do not think that they are precise enough for you but there you go.
Hope this helps!
Author:  Chris Paulick [ Sun Feb 15, 2009 9:39 am ]
Thanks Steve.
I know about the drill bit thing as that's how I've made different size dots in the past . It's very time consuming and I'm looking for a faster method, Looks like I just might come up with another router jig. Maybe a road trip to Woodcraft today.
Author:  ChuckB [ Sun Feb 15, 2009 4:08 pm ]
Chris, I don't think this will work on shell, but I have used a piece 3/16 brake line and sharpened the outside to a bevel, chucked in the drill press and cut cherry position markers...worked great.
Chuck
