Herringbone purfling http://w-ww.luthiersforum.com/forum/viewtopic.php?f=10101&t=21601 |
Author: | Jimmy Caldwell [ Mon Mar 23, 2009 11:14 am ] |
Post subject: | Herringbone purfling |
I'm sure I've seen a tutorial on making herringbone purfling, but I don't seem to be able to find it. I'm in need of some for some 1890's vintage style guitars that is somewhere between the two sizes that are currently available at most suppliers. Does anyone know where I can find either the purfling or a tutorial so I can make it. TIA. |
Author: | Howard Klepper [ Mon Mar 23, 2009 12:36 pm ] |
Post subject: | Re: Herringbone purfling |
Mick Lazar put one on MIMF several years ago. |
Author: | Laurent Brondel [ Mon Mar 23, 2009 12:45 pm ] |
There is one in Bogdanovich classical guitarmaking book. |
Author: | Hupaand [ Mon Mar 23, 2009 1:13 pm ] |
Here's one. http://www.gurianinstruments.com/help/p ... rHelp.php# or this one half-way down the page http://mimf.com/library/catalog_bending.htm#binding |
Author: | Chris Paulick [ Tue Mar 24, 2009 9:32 am ] |
I can't see anything in those links on how to do it. |
Author: | WaddyThomson [ Tue Mar 24, 2009 10:10 am ] |
For what it's worth, I did a tutorial on making wheat (same process as making herringbone, except without the center strip) over on Luthier Community. I did two batches. The first, I did not like, as it was breaking up too much when cutting the small strips. Poor gluing is what I attribute that to. The second batch on the second page of the thread, came out much better. The whole point is, don't try to glue too much at once. Glue maybe four to 6 layers at a time, then clamp and let dry, really dry. Overnight is best, but several hours will work. Then come back and glue another set, clamp and let dry. When you glue too many layers at once, too much glue dries before the clamps are on, and the curling veneer, will create it's own gaps in the layers. They are small, but they'll cause strips to break at joins. I got my methods from the Bogdanovich book. I'll be glad to answer any questions I can. Either here or over there. HERE IS THE LINK |
Author: | Bill Hodge [ Tue Mar 24, 2009 10:22 am ] |
Howdy from Colorado Chris, Here's a slightly different link for the purfling building calculator http://www.gurianinstruments.com/purflingBuilder.php# The link in Hupaand's post is for the help screen to use this calculator. ![]() It's primarily for a build your own design so they can make what you want as far as I can see. ![]() Here's a PDF of a tutorial on making purfling and it has some pics. |
Author: | Bill Hodge [ Tue Mar 24, 2009 10:26 am ] |
I should have paid closer attention, I just noticed you said "Herringbone Purfling" ![]() Looks like Waddy's gotcha covered. And he's got me covered too for that matter ![]() |
Author: | Bill Hodge [ Tue Mar 24, 2009 11:14 am ] |
Chris, Here's a couple of links to some excellent tutorials in addidion to Waddy's, They are specifically on making Herringbone Trim and Meander Motif's. Excellent pics as well. http://billsguitarshop.blogspot.com/2008/02/making-herringbone-trim.html http://billsguitarshop.blogspot.com/2008/02/making-meander-motif.html Well, gotta finish my snack and head back out into the shop ![]() |
Author: | luthier1990 [ Sun Jun 27, 2010 8:00 am ] |
Bill, im having trouble seeing those links you posted, does anyone else know of another source on how to construct the meander patter used by Torres, Romanillos and the like Thanks, Paul |
Author: | WaddyThomson [ Sun Jun 27, 2010 9:32 am ] |
David La Plante had an article in Guitarmaker a few issues back that was pretty good. Not high in detail, but if you know the basics, that's all you need. It ain't rocket science. |
Author: | JohnAbercrombie [ Sun Jun 27, 2010 10:42 am ] |
Howard Klepper wrote: Mick Lazar put one on MIMF several years ago. Thanks for that reminder, Howard! |
