It is currently Mon Aug 04, 2025 1:10 am
 Post subject: System 3 shelf life?
PostPosted: Fri Mar 27, 2009 9:52 am
Well, today was supposed to be the big day -- after many hours of fastidious preparation, I'm ready to start pore filling #'s 4 & 5. I was deep into cleaning up the shop in preparation for its role as spray booth when I grabbed the sb-112 from the flammables cabinet, only to notice the bottom half of part A had turned a milky white, and had begun to harden. The top half seemed fine, and when I used it a week ago on the fingerboard, I hadn't noticed a thing, and it performed just fine.
My question is this: if the top half is still clear, and looks normal, is there any reason not to go ahead and use it, or should I trash it, order new, and sit on my hands for the next several days till it arrives? Or, does anyone know of a similar product that may be available locally?
Thanks as always.
Ken
Mountain Song Guitars www.mountainsongguitars.com
 Post subject: Re: System 3 shelf life?
PostPosted: Fri Mar 27, 2009 10:00 am
I'm all into using stuff as long as I can (I refrigerate my HHG and use it till it starts looking bad) but when things start changing in appearance, I trash it.
I used Z-poxy finishing resin in my last pore fill and it worked really well. It can be found at most well stocked hobby shops.
PostPosted: Fri Mar 27, 2009 10:17 am
Place the bottle in a bath of hat water and it'll return to its normal state.
Glue up a test joint to verify it.
PostPosted: Fri Mar 27, 2009 10:29 am
What Jim said. If it returns to normal after a hot water bath it is most likely fine. I would test it for cure-ability.
Mix it and put a blob on some wood or plastic or something and test how well it cures. If it cures well it is strong.
I think you will get more out of that kind of test than a joint.
Link
PostPosted: Fri Mar 27, 2009 10:59 am
Thanks y'all for your speedy responses -- Link and Jim, that's what I was hoping was the case. And Andy that's great to know that the West Systems may be available locally -- I've been wanting to try them out anyway. Happy days!
Ken
PostPosted: Fri Mar 27, 2009 11:31 am
Wished I'd known that before I threw mine out about 3 wks ago cause it started to harden.
PostPosted: Sat Mar 28, 2009 3:34 pm
Update:
Heated up part A in a hot water bath, it returned to its thinner, clear state, and it worked like a charm. Thanks, fellas!
Ken
