CA drop fill over varnish?
http://w-ww.luthiersforum.com/forum/viewtopic.php?f=10101&t=21699
Author:  George L [ Sun Mar 29, 2009 10:35 am ]
Post subject:  CA drop fill over varnish?
I've used CA to drop fill over lacquer before and it ended up basically invisible. I've found a couple of small areas along the binding/purfling of a guitar that I've finished in Pratt & Lambert #38 varnish that could use a little touch up and I'm looking for some advise. Anyone have any experience drop filling over varnish?
Author:  George L [ Sun Mar 29, 2009 2:24 pm ]
Post subject:  Re: CA drop fill over varnish?
Good idea about letting some of the varnish thicken and then using it to drop fill. I'll give that a try. Thanks!
Author:  Laurent Brondel [ Sun Mar 29, 2009 2:47 pm ]
As long as you spray/brush another coat over it, CA dropfills under varnish will look invisible.
Author:  George L [ Sun Mar 29, 2009 5:26 pm ]
Laurent,
Thanks for your response. I know you have extensive experience using varnish and was hoping you might add your expertise to this thread. I have scrap pieces to test on, so I'll be experimenting a bit before continuing.
Thanks again,
