It is currently Mon Aug 04, 2025 8:14 am
PostPosted: Thu Apr 02, 2009 4:21 pm
Last Name: Hodge
Has anyone here ever used Alaskan Yellow Cedar for Bracing and or Linings? Or do you know of someone
who has with good results? Just curious because I have a bunch of it and I'm considering some for necks
and the rest for bracing and lining stock if that's a feasible option.
I'd like to thank everyone who will for their input in advance. Gotta head back out to the "man cave" :D
Bill Hodge
PostPosted: Fri Apr 03, 2009 12:31 pm
Last Name: Hodge
Bump Eat Drink
Bill Hodge
PostPosted: Fri Apr 03, 2009 1:10 pm
Would work ok for linings but I wuld think it may be too subject to movement for necks, Spanish Cedar a better choice for necks
PostPosted: Fri Apr 03, 2009 1:54 pm
Last Name: Hodge
Thanks Michael. As always, I appreciate your wisdom on this. :D
I posted this yesterday and was beginning to think maybe I had bad breathe or something. :mrgreen:
Bill Hodge
PostPosted: Fri Apr 03, 2009 2:30 pm
First name: Woodrow
Last Name: Brackett
City: Grover
Zip/Postal Code: 28073
I've got a 000-12 fret out there that's a little over a year old with a Yellow Cedar neck. It's a 3 piece neck with 1/4" Mahogany in the middle. It's alot lighter than Spanish Cedar. I'm sure it would make great linings. IMHO it's stiff enough for bracing, but is it a little heavy?
PostPosted: Fri Apr 03, 2009 2:54 pm
Now a laminated neck would likely be fine
PostPosted: Fri Apr 03, 2009 4:24 pm
First name: Daniel
Last Name: Minard
City: Powell River
State: BC
I built a classical guitar several years ago using all yellow cedar, including the neck. I put a double acting truss rod in the neck & it has not been a problem. I haven't needed to adjust the rod yet. YC is famous for its stability. (Once it has been properly dried)
Yellow cedar is very soft & dents easily, so expect to get "bruises" over time.
I would not use it for braces, based on a friend's experience of building his "worst ever sounding guitar". He blamed it wholly on the YC bracing. (Grain 'O' salt)
I do use it for kerfed linings, & intend on using it on my next project which will have laminated, solid linings.
Careful with the dust... One can quickly become sensitive or allergic to the stuff.
Users browsing this forum: bobgramann, DennisK, meddlingfool and 6 guests
